ecphoto
- Joined
- Mar 6, 2012
- Messages
- 320
- Reaction score
- 18
- Location
- Southern California
- Can others edit my Photos
- Photos OK to edit
Pointed head on, the Fong Dong or the wide angle panel won't really improve your lighting at all. Well, the Fong will help a little if you are really close to your subject, but otherwise, not much.If I have to point it head on like I did here what would
you suggest, could you link the wide angle plastic attachment your talking about?
The main thing that we are trying to do, to improve the light from our flash, is to soften the light. The ONLY way to soften light, is to make the source bigger and/or move it closer to the subject. In other words, to make it softer, it has to be bigger, relative to the subject.
So with that in mind, look at all the flash accessories. The Fong Dong does make the light source a little larger, but not by much. At the same time, it's throwing light everywhere. The Omnibouce doesn't increase the size, the Flip It barely increases the size, the wide angle panel doesn't increase the size at all. No any of those options, doesn't really give you softer light...when it's being used directly to the subject.
But that's why we bounce. When you bounce light off of the wall or ceiling, the light source becomes the area that the flash beam is hitting...which will be quite large (unless you are really close to the subject). So that's why most of these accessories are meant to be used in conjunction with bouncing the light off of walls or ceiling etc. So when you consider that, the quality of the surfaces around you, will dictate how effective these accessories can be.
If you are in a situation where you can't (or don't want to) bounce...then your best bet for improved light from your flash, is to enlarge it (or, of course, get it off the camera). So it enlarge the light source, you could use something like an umbrella or softbox (not a great or possible when the flash is on-camera). That's why I carry the Super Scoop. That is about as big of an object that I can have attached to my camera/flash.
Of course, with all this talk of improving your flash....you still need to able to control your flash exposure and your ambient exposure. And being able to control the balance between the two. If you can't do that, the accessories won't matter much.
Well I usually control the balance of ambient and flash with ISO and longer shutter speeds when needed. I stopped using Av in this scenario because I don't like how little control I get. One of my friends uses the scoop and swears by it, is a DIY scoop good enough or is it not as good as the one by light-genius?
