...take a look at the blown highlights on the little boy's head.
I noticed that both of your files, although small in dimension, are very large in bytes.
This is due to saving them in 'high' quality.
That is appropriate for files that are meant to be printed and/or have lots of fine detail but is unnecessary with files that are going to be viewed at screen size on the web. You could save this at much lower quality and reduce the file size by 50% or more without seeing any difference on the screen.
It is very close to being over exposed, and the specular highlight seems to be extending into lower zones.
Might have helped the sky a little, but...
- First, you need a camera with high dynamic range (like: D3200, D3300, D5200, D5300, D5500, D7100, D7200, D600, D610, D750, D800, D800E, D810, D810A, DF, D4s).
- Second you need to expose the shot to the highlights, not the shadows. The D750 and the D810/A have the new Highlight-Weighted Metering mode, that does that very well.
- Third, make sure you're uing RAW file to shoot, not JPG.
- Fourth, in RAW file post-processing, recover the shadows of the shot, whiling keeping the highlights without blowing up, and adjust any other parameters.
- Last, after you're satisfied, convert it to JPG and be happy.
Or, expose to the highlights and just use a flash to bring up the shadows while shooting.
Good luck!
