CorrieMichael
- Joined
- Sep 28, 2012
- Messages
- 447
- Reaction score
- 166
- Location
- Canada
- Can others edit my Photos
- Photos OK to edit
I'm probably not a good person to c&c this but the one thing that stands out to me is how inconsistent the lighting is on the grass and pool. The second is WAY brighter, but the background is the same in both.
To me neither is clearly better, they are just different.
Is there not some vignette applied?
Did you use an action or something? The coloring and WB looks really unnatural.
Weird... I would have sworn on a stack of Nikon manuals that a vignette had been applied to this!
Full frame cameras really put a lens to work; if you don't want vignetting you will have to gets some very expensive glass.
MOST lenses will show significantly MORE vignetting (light fall-off at the edges of the picture area) when the lenses are shot on a larger FF sensor than when they are used on a smaller, "crop-frame" sensor. So...that's pretty much par for the course. If the fall-off bothers a person, the "Enable Lens Correction" option in Lightroom usually will eliminate most of the vignetting in one click. Almost all fast 50mm lenses exhibit pretty significant vignetting on full-frame until the lens is stopped way down (like to say f/7.1 or even f/8). EXIF show f/1.6 on this shot, so...yeah...it is to be expected that there will be vignetting with that lens shot that wide-open.
Is there a similar function in ACR for the lens correction option that you speak of in Lightroom?
