kylesfreelance
What exposure setting is good for concerts and events.
ISO 3200, f/8, 1/125.
Note, however, that this setting may or may not work under the conditions you are shooting. It may be too much for someone in the spotlight, and too little for someone in the audience. Maybe you should ask a different question: how to determine the right exposure to use in a dark (or bright) showplace environment. It also depends on whether you're shooting from the nose-bleed section or on stage. Tell us more about what you're trying to do and what equipment you are going to do it with.
Ok concert wise wiill be mostly indoors. I have a d5100 with 18-55 lens. For event photography mostly outdoor with a d 5100 and 18-55 lens.
You've got the same sensor as my camera. And I'll tell you this much. You don't want to shoot at 3200 ISO with it. It's not terribly grainy, but you won't be happy with the results
That's the first I've heard this.
It's still going to boil down to the conditions. Don't take this as trying to pile on or pick on you, but when you ask "what settings?" it means you don't understand exposure. Exposure is the right combination of ISO, Aperture and Shutter speed for your given conditions. They will vary from shot to shot. So you can't really ask for settings.
EXACTLY! The only person you could ask is a photographer standing next to you at the event. And if you do that they are going to look at you funny.
Study the exposure triangle!!!
