Camera won't shoot with lens on
asneakypanda
Okay so I have a Sears KS Super II, SR2000, that i just got yesterday from a camera swap. It came with a 35-200 mm Tokina AT-X lens. I got a battery for it and checked the shutter and everything worked fine. But today I was gonna go out to take some pictures. So i tested it one more time and the shutter kind of halted. I press the shutter button and I heard a faint *click* but the shutter doesnt open all the way. Yet when i take the lens off. I can shoot for days. Does anyone have any suggestions as to what the problem is? It shoots fine without the lens on it. But sadly i dont have another lens for this camera right now.
ak_
You have the back open on the camera and you can see the shutter half open? Is the camera fully manual or is it aperture priority only? Try to close the iris on the lens unmounted - depress the auto pin. Perhaps a sticky/stuck iris prevents the shutter from activating if the body couldn't stop it down. As it works without the lens the mechanism linkage seems the problem. you could set the aperture fully open and test this mounted on the camera.
OP
OP
A
asneakypanda
The shutter on the back wont open at all. It sounds like the pin is only going 1/4 of the way. And when i hold down the shutter button you can hear constant clicking. The camera is aperture priority only with the exception of a setting that allows you to exclusivly use 1/100 s shutter speed. It does the machine gun clicking on that mode which is called "X" on the camera. The iris is working fine as well and nothing is getting stuck. It is only when the lens is on the camera. I can't quite seem to pinpoint the problem
ak_
This it?
Sears KS Super II, Sears cameras, KS super
Try B (bulb): remove the lens. Cock the shutter. Press and hold down the shutter button. While pressing and holding down the shutter button in B, mount the lens, then release the shutter.
timor
Toronto ON
Lens you have is purely mechanical, once mounted engages a resistor which tells the exposure calculator what aperture the lens is set for. If the resistors is broke, (might be a short, it is low end old camera after all), it may send some weird signal and calculator goes bersek. I think that's it for the camera. RIP.
OP
OP
A
asneakypanda
Mmm that sounds like that's the problem. Thank you for the input :)
OP
OP
A
asneakypanda
Bin the camera and get a mechanical camera that does not need batteries
Yea I have other cameras that I can use. But it saddens me bc i really wanted to use that one. Oh well though. To the bin :)
gsgary
Chesterfield UK
Website
www.gsgary.smugmug.com
I've never heard of the camera so it must be a very basic camera
timor
Toronto ON
Not so basic, basic is K1000, this one has autoexposure. But off course nothing remarkable. It is rebranded Ricoh.
Derrel
Mr. Rain Cloud
USA
Website
www.pbase.com
Have you tried setting the ASA/ISO dial to 400 ASA, then setting the lens to f/2 or f/2.8 and pointing the camera at a BRIGHT scene? WIll it fire with the lens set to a wide aperture? I am wondering if indoor lighting and a low ASA setting in A mode are causing an issue.
And, according to the manual I saw, it does have Bulb mode, the little "B" on the switch.
I am also wondering if that lens you have "might" be a K-A mount lens, with the little "A" button dealio on it (to one side of the 22 or 16 number setting on the lens's aperture ring), and not really era-appropriate for the camera body???
compur
L.A.
At the rear of the lens there is a small lever that engages another lever inside the camera's mount for actuating the lens diaphragm (aperture). It's possible that this lever on the lens is stuck or bent and won't allow the camera to complete the exposure cycle when that lens is mounted. I suggest trying to move that lever on the lens to see if it moves freely and if it operates the lens diaphragm when moved. Do this with the lens aperture ring set to its smallest aperture (22).
If this lever isn't working properly then a different, working lens should solve the problem.
OP
OP
A
asneakypanda
Mmm. Yes i tried that. Even with wide aperture and bright light it doesn't work (shutter). My camera doesn't have a B on it however. Just L, A, and X... And my lens doesn't have an A button on it either, but I believe you are right about it not being a era appropriate lens
OP
OP
A
asneakypanda
The lever on the lens isn't bent or stuck and it moves very freely
