fmw
Alex_B said:coatings and reflections can be an issue where differences occur ...
Not in our test, Alex. We sent 6 pro photographers to put a number of filters through their paces. We asked all of them to try to produce flare. All of them were able to produce ghosting, with or without coating and none of them were able to produce visible flare, with or without coating. We were never able to tell a coated filter from an uncoated one in the results. Nor were we able to tell an expensive one from a cheap one. In the case of UV filters we were never able to tell a filtered image from a non filtered image except in those instances where the photographers generated ghosting with the filters. It takes extreme lighting right into the lens to produce ghosting, as you know. If you need to shoot that type of light, simply remove the filter.
It is possible that some flare could exist because of the filter but it was certainly not visible under a 16X loupe or in a transparency projected full screen. It is not hard for me to see flare in a zoom lens adjusted to the same focal length as a fixed focal length lens. The fixed lenses are always contrastier. It is impossible for me to see it by adding a UV filter and was impossible for the other 5 pro photographers in the test as well.
This filter business is an old myth. It needs to go away. I've tried but I have no credibility. Perhaps someone with credibility will run the tests one day and be done with it.
