Thanks so much. I have the canon 430 exII and sb-800 but was wondering if was necessary to buy the yongnuo 560iii?
The YN-560 III has built in triggers that work with their YN-602 and YN-603 triggering systems. I just bought 4 of them, and they work terrific with my YN-603 transceiver on the camera's hot shoe.
I don't know that the YN-560 III's built in triggers would work with anything other than those two triggering systems however. On the flash, you choose in the menu which triggering system to use; the 602 or 603. My triggers are the 603 series. When I set it to 602 just to see what would happen, it wouldn't fire. It had to be set to the 603 in order for the 603 triggers to fire it. I strongly suspect from that test that the CS triggers won't work with it, whether it's set to 602 or 603.
If someone actually has the CS triggers you're looking to use AND the YN-560 III flash, they can tell you directly if the flash's internal trigger works or not. I don't have the CS triggers, so I'm only speculating here.
If you're planning to park the YN-560 III on top of a CS trigger, that would probably work to fire it, but then there's no sense paying extra for the built in trigger, unless you're planning to use YN RF-602 or YN RF-603 triggers later. But if that's the plan, why not just go with those instead of CS triggers up front? If you don't plan to use the YN triggers later, and you still want a YN flash, I'd say get a cheaper one with the same guide number that has no built in trigger system.
On the other hand, if you go with the YN 602 or 603 triggers instead of the CS triggers, you may need to mix and match them to the Canon and Nikon flashes. Maybe someone who actually has all the gear to test it can tell you if the RF-603-C (canon trigger) will fire a Nikon flash, or vice versa, the RF-603-N will fire the Canon flash. I just don't know, but it's hard to believe they make one of each if just one of them would fire either brand.
The whole mixing of gear brands is making this kinda complicated. What camera body(s) are you using? Have you considered selling one brand and using the money to get the other, matched to your body brand, for consistency?
