Darkroom ventilation, no outside wall.
Shari Denson
Hello, I'm hoping to set up a wet darkroom above my friend's shop. It's on the middle floor, in the middle of the building. There are no outside walls to the room but there is a kitchenette (used for making the odd coffee) in between the darkroom and the outside.
I'm worried about ventilation, and wondering if I install a light tight fan in between the darkroom and the kitchen, and leave the kitchen window open, will that work? I'm mainly worried as I hope to invite others to use it with me.
I've never set up a darkroom before, although I've used a few, so a bit overwhelmed.
Any advice would be appreciated.
480sparky
Chief Free Electron Relocator
Supporting Member
Iowa
Website
pixels.com
You might be able to run ductwork parallel with the ceiling joists to an outside wall. Not easy or fun, but the best solution.
Designer
Iowa
.. wondering if I install a light tight fan in between the darkroom and the kitchen, and leave the kitchen window open, will that work?
I certainly would not do that. first; it would be contrary to building code, and adding the odors of the darkroom to the kitchenette does not sound appealing. Better hire someone to install the fan according to code.
The_Traveler
Completely Counter-dependent
Supporting Member
Mid-Atlantic US
Website
www.lewlortonphoto.com
I had that situation years ago - a darkroom in a unfinished cellar space - and ran two vents to a large open, ventilated space. One was was set up as a pull-fan and the other a push fan on the darkroom end. Both were connected to about 10 foot plastic accordian-type tubing.
It wasn't as successful as I'd like because the vent openings in the darkroom end were too close together and didn't exhaust the room well.
If I were to do it again, I'd push air in from one lower corner and pull air and fumes out from another top corner. This did increase the dust problem but it was a fair trade-off.
pixmedic
I am the Lord thy Mod
Staff member
Supporting Member
Central Florida
Website
www.flickr.com
I recommend one of these.
no house modifications needed.
