DX vs FX focal lengths?
Discussion in 'Nikon Cameras' started by darkblue-x, Oct 23, 2017.
  1. Overread
    May 1, 2008
    24,953
    4,609
    UK - England
    The angle of view (what you see through the viewfinder and get on the sensor) of DX at 16 is equivalent to FX at 24mm.
    To convert the angle of view of a DX to FX you multiply the DX focal length by 1.5
    To convert the angle of view of a FX to DX you divide the FX focal length by 1.5
    NOTE focal length is always the same, a DX 16mm lens and an FX 16mm lens on a DX camera body will give you exactly the same angle of view. With Nikon many of their FX camera bodies can let you use a DX lens on it by activating only a portion of the central area of the sensor, as a result you'd get the DX lens performing as if it were on a DX camera body
    FX = fullframe or 35mm
    DX = crop sensor (cropped in terms of comparing it to 35mm)
  2. Designer
    Designer Been spending a lot of time on here!
    Apr 13, 2012
    18,307
    4,776
    Iowa
    You can get fairly close with the 24-70.
    No.
    Wider.
  3. astroNikon
    astroNikon 'ya all Bananas I tell 'ya Supporting Member
    Aug 15, 2013
    13,649
    3,325
    SE Michigan
    Your viewfinder may not show 100% of what your sensor sees. It may only show 95%. So composition of a subject has to take that into consideration if no post processing.
    The MIRROR's size is based on the sensor size. Thus the VIEWFINDER will only show you what the Mirror reflects. Technically you could have a mirror 3x the size of the sensor and the viewfinder would show you a gigantic area of which most won't be captured.
    Generally, The lower end camera the darker and less of the actual subject size is shown - it's not by much but it's still there.
    viewfinder info ==> APS-C field of view
    But that mirror size, based on the Sensor size - the sensor defines the FOV which may change what a lens "sees".
    If you have a lens that is a 24-70 that lens is designed as a 24mm-70mm.
    On a Full Frame Camera which is considered 1x (as it's the base) makes that lens FOV as a 24-70.
    On an APS-C camera which is considered 1.5x makes that lens FOV as a 36-105.
    To compensate on a APS-C camera you need a 16mm lens to get the (16x1.5) FF 24mm equivalent on a FF sensor.
    ==> DX Lens Focal Lengths
  4. darkblue-x
    darkblue-x TPF Noob!
    May 9, 2017
    146
    10
    Ottawa
    So then 24mm FX is the same FOV as 16mm on DX?
  5. Tomasko
    Tomasko No longer a newbie, moving up!
    Oct 17, 2010
    708
    76
    Yes. It's really just the most basic multiplication/division...
  6. darkblue-x
    May 9, 2017
    146
    10
    Ottawa
    soooooo then the FOV that an FX lens 24-70 gives off is similar to a standard zoom FOV on a DX of 16-45 or 50?
  7. Tomasko
    Oct 17, 2010
    708
    76
    70 / 1.5 = roughly 46,67
  8. Ysarex
    Ysarex Been spending a lot of time on here!
    Nov 27, 2011
    6,406
    3,013
    St. Louis
    Yes.
    • Like Like x 1
  9. darkblue-x
    May 9, 2017
    146
    10
    Ottawa
    Okay finally. I made that calculation weeks ago, everything else ITT served to confuse me further.
    that's an okay focal length on the lower end, lacking a bit on the longer end though...
    I saw that nikon makes a 24-120 lens though.. should I move on to FX maybe I should get that.
    third party lenses are the same thing arent they?
    and what if its a PRIME FX lens like 35mm? are they the same between DX and FX? Id imagine they make the DX lenses to make the FX equivalent in DX format and same with FX.
    I may just be best going to the Camera store, I am a visual learner it may be easier having someone show me with the cameras and lenses physically for it to fully compute.
  10. Tomasko
    Oct 17, 2010
    708
    76
    Focal lengths are (to my knowledge) always written in respect to 35mm / fullframe. It doesn't matter if it's Nikon/Canon/Sony/whatever brand, it's still the same thing. It also doesn't matter if it's a zoom lens, macro lens, telephoto, prime.. If the lens says for instance "24mm", you know they mean it gives you 24mm FOV on a fullframe camera and different FOVs on different sized sensors based on the crop factor.
  11. darkblue-x
    May 9, 2017
    146
    10
    Ottawa
    I'm confused again because the FOV of 16mm DX on FX is 24mm.
    So then 35mm DX on FX is???? 50mm FX? To get a prime with same FOV as my 35mm DX do I have to buy a 50mm on FX?
  12. Ysarex
    Nov 27, 2011
    6,406
    3,013
    St. Louis
    No. My compact is here on my desk. The zoom lens is inscribed 5.2mm - 17.2mm, f/1.4 - 2.7. It has an equivalent FOV on the wide end that's the same as a 24mm on a FX camera or a 16mm on a DX camera.
    There have been camera manufactures that inscribed lenses with FF equivalent focal length values --a horribly bad idea -- but typically they note that when they do it.
    Joe
    • Agree Agree x 1
compare dx focal length to fx focal length
dx fx focal length math
dx lens vs fx lens focal length
dx vs fx field of view comparison
focal length dx fx
focal length dx vs fx
fx vs dx focal length comparison chart
