Err 01
Discussion in 'Canon Lenses' started by chrisja77, Mar 24, 2012.
  1. chrisja77
    chrisja77 TPF Noob!
    Nov 28, 2011
    22
    Marion, AR
    I've got a few month old Canon T3i that has worked great till this morning...and I'm getting ready to go to the zoo! AAARRRGGGHHHH Anyways, it works just fine with my 18-55mm lens but when I switch out to my 55-250 I get the Err01 message that the camera can not communicate with the lens. I've cleaned the contacts and made sure none were stuck down but still no luck. I've also removed the battery with the same results. When I try to change the aperture settings it says F00 and "no lens attached". Anything I've overlooked or is it time to have a lens replaced....both lenses were bought new with the camera for christmas... The lens worked just fine when I used it about a month ago and it's been stored in a secure hard case since then.
  2. Overread
    May 1, 2008
    25,167
    4,733
    UK - England
    Did you clean the contacts on both the lens and the camera body?
    If that does not solve things it means you'll have to send the lens in for a check-up. Hopefully its a manufacture error/problem and thus covered under warranty.
  3. chrisja77
    chrisja77 TPF Noob!
    Nov 28, 2011
    22
    Marion, AR
    Would I be better going to Canon directly or checking out a local Canon dealer?
  4. IgsEMT
    IgsEMT No longer a newbie, moving up!
    Jul 27, 2009
    2,694
    49
    NYC
    I'd go to Canon directly. Depending on where you bought the camera, dealer might give you hassle about it. However, call Canon before sending it in, they might run some over the phone troubleshoot.
    Good Luck
  5. 2WheelPhoto
    2WheelPhoto TPF Noob!
    Apr 14, 2011
    6,844
    994
    Tampa
    Contact these folks for advise:
    Canon Customer Support Center
    Phone: 1-800-OK-CANON
    1-800-652-2666
    TDD: 1-866-251-3752
  6. chrisja77
    chrisja77 TPF Noob!
    Nov 28, 2011
    22
    Marion, AR
    Thanks for the advice....I ended up dropping it off at my local Canon dealer and they shipped it to canon for warranty work before I saw the phone numbers. I'll keep my fingers crossed I don't get screwed around to bad.
18-55mm er 01 f00
err 01 canon 55-250mm
