Exposure Area & TV With Flash
Discussion in 'Lighting and Hardware' started by ElizaMM, Jun 11, 2018.
  1. ElizaMM
    ElizaMM TPF Noob!
    Aug 22, 2015
    53
    As someone suggested, I purchased a Yongnuo RF603C II, for use with my Canon 7D and realize now, that I don't understand flash lighting.
    As a test, I was photographing a chair in indoor daylight & used a fairly fast exposure.
    At 1/320s, F32, ISP 100, the picture is over exposed. When I reduce the TV,
    to 1/500x, keeping the F-stop and the ISO the same, the top half of the picture is correctly exposed, but the bottom half is black.
    I haven't found a solution online and would appreciate any suggestion you may have.
  2. Nwcid
    Nwcid No longer a newbie, moving up!
    Jan 8, 2018
    227
    122
    PNW
    1/320 is usually too fast of a shutter speed for flash. What you are seeing is the mirror not fully open. Usually you need sync speeds of 1/250 or slower, like everything else there are exceptions.
  3. adamhiram
    adamhiram No longer a newbie, moving up!
    Feb 6, 2015
    294
    164
    The maximum flash sync speed on the Canon 7D is 1/250s. Any faster than that and you'll see the shutter's rear curtain, which will appear as a black bar on your images. Use 1/250s or slower.
  4. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    41,903
    15,970
    USA
    TV typically photographs well at f/8 at 1/8 second at ISO 400...somewhere in that general range. You need a rather slow speed, to eliminate a lot of scan bars on the TV image. If the shutter speed is very fast, the flash might create black barring. If one uses too much flash power, it can "wash out" the TV image.
  5. ElizaMM
    ElizaMM TPF Noob!
    Aug 22, 2015
    53
    Thank you for the explanations--I should have asked for advice, before wasting time, trying it over and over. I will try the f/8 at 1/8 second at ISO 400, today.
  6. keen.observer
    keen.observer TPF Noob!
    May 4, 2018
    62
    6
    When I snap something on the tv screen, I use auto ISO, at F/5.6, and either 1/60 of a second, or 1/125 of a second, on my Nikon D7200. It works.
  7. keen.observer
    May 4, 2018
    62
    6
    I don't use a flash for tv pix, as the screen provides enough light.
  8. zombiesniper
    zombiesniper Furtographer Extraordinaire! Supporting Member
    Jun 23, 2015
    6,259
    4,183
    Angus, Ontario
    Lets make sure of something here before we introduce a possible second problem.
    ElizaMM, are you stating you're shooting a Television, or are you shooting in TV (Shutter priority) mode on your camera. These will have two different answers.
    I believe the second to be more the case.
  9. john.margetts
    john.margetts No longer a newbie, moving up!
    Dec 3, 2015
    1,101
    272
    Lincoln
    She is clearly using Tv which usually has a lower case 'v'.
    Sent from my 8070 using Tapatalk
  10. zombiesniper
    Jun 23, 2015
    6,259
    4,183
    Angus, Ontario
    Agree but not all are familiar with Canons weird dials
  11. ElizaMM
    ElizaMM TPF Noob!
    Aug 22, 2015
    53
    I meant time value.
