Hand held HDR
earthian
Ahmedabad, Gujarat, India
This was one of my first attempts at HDR ( processed in LR6). Hand held at Pearl harbour:
I am not seeing much detail in the shadows here.
Was this one exposure?
Also, this is not a scene you typically use HDR for. There's not going to be a ton of difference, even if you do happen to nail it.
It looks a bit flat for HDR. The whole point of HDR is to expand the view that the camera took. I know the norm is to minimise the HDR / Tone mapped look but in this example I would take it a wee bit further. See below made from your posted pic and 2 brighter versions.
The fist one is a bit over the top but I like it and the second is a bit more conservative but still brings out a wee bit more of the shadows than the one you posted.
black clouds on solid gray skies--just like real life!
Really EXPANDING what the camera can capture here:
The second edit is close, but still needs more whites. Still very flat.
Nice photo but I'm with Manaheim on this.
There were three exposures, one stop under and one stop over.
Would be interested in knowing why this is not a preferred scene for HDR. (Apart from the issue of merging all the leaves in the wind)
Thank you guys. Now that you all have mentioned it, does look a bit flat.
i rather like the one @Braineack has posted.
Incidentally, it was a dull and overcast sky!
Yes expand! !
For me the final edit may or may not have anything to do with reality.
HDR / Tone mapping is an opportunity to make a picture look the way you choose to make it look.
you've significantly clipped the blacks while failing to expand the whites, you reduced the DR significantly in that edit.
its disgusting.
