handluggage problems
Alex_B
Europe 67.51°N
ok, here comes my problem:
due to recent developments in handluggage restrictions combined with some expansion of my photographic gear, my usual way of transporting my gear on planes in Europe and around the world has become impossible.
Things I would never want in my checked in luggage include:
- at least one Canon SLR Body (more on the large side here)
- 17-40mm 4 L lens
- 24-105mm 4 L lens
- 300mm 4 L lens
- 50mm 1.4 lens
- 1.4x converter
- close up lens and 5 filters
- hard drive based image storage
- 14' laptop (1.9 kg)
the rest would be fine to check in, but the things above are just too fragile in my eyes.
so what do you guys use to transport a maximum amount of camera and glass in your handluggage without facing problems regarding size and weight?
was anyone of you ever forced to leave something behind since you were told you had too much handluggage and your main luggagge was checked in already? for me this would be a nightmare!
I have about 2 flights a month, and it never happened to me, but i am about to stretch the limits now but don't want to get into trouble ....
any advice welcome
I wish I could help, unfortunately I can't really say what I'd do, as the last time I flew was last August at the time of the big scare at Heathrow. I was actually due to fly home into Heathrow on the day it happened, and when I heard about the restrictions on hand luggage I panicked since I thought I would have to check my camera bag in with the main luggage. As it happened, Vienna and Brussels airports did not at the time have the same restrictions so I was able to take my camera bag as hand luggage. However I wasn't carrying a laptop with me, nor any lens the size of your 300mm.
I agree that it's not worth risking checking the valuable stuff in. Personally I don't have enough faith in the airlines and airports to be confident that my gear be both present and intact on arrival. I guess all you can do is to pack what you can into a bag or case of acceptable size. If it is still possible to also carry a camera around your neck, filters (cased) in jacket pockets etc then that might be necessary though clearly not very convenient.
if you leave the uk, flybe seems to be pretty relaxed with handluggagem they allow for 10kg! :) but with everything else it is complicated these days .
no further advice? :(
noone got the perfect solution for me? ;) .. well , I guess there is no perfect solution then ....
I've heard of people wearing a photovest with the pockets loaded . . . it's not carry on . . .it's outerwear <g>
The most ingenius solution I've heard sadly won't help you as it only works on U.S. domestic flights. A gentleman reported researching the issues concerning flying with firearms in checked baggage. Turns out on domestic flights there is a rather formal ritual which includes presenting your carrying case to an airline official who then inspects it and witnesses you placing YOUR padlock on the case (retaining the key yourself) This luggage is then watched by suspicious hawks selected because they don't particularly like each other. On the destination end the firearm containing luggage is hand delivered to the traveler who signs for it.
Not photographic, you say? <grin> Here's the kicker . . . . further research revealed that no U.S. state or federal law defined a starter pistol . . . a small quasi handgun used to start trackmeet races . . . as a controlled firearm, BUT the airlines did consider the blank firing pistol as a firearm. He now carries a starter pistol in each and every camera case and reports no problems.
Getting practical it would seem that your only solution is insurance.
Well, all I can tell you is that I was facing problems with a young official at Stansted on my return from the UK on 3 September of last year, for she felt she had to return me to the check-in counter for me to check in my (not very large!) camera rucksack, even though I had already squeezed my "kangaroo bag" (I know they are "officially" called "bum bags" in some parts of this world... do you all know what I mean?) into the check luggage as not to have TWO (albeit two small) handluggage items on me. But since I had to then squeeze my purse into the front part of the camera rucksack, that became a bit bulkier than normal, so it would not fit in the "test if your handluggage fits in here"-device. (Designed for attaché cases ... LARGE attaché cases, with lots more room for things than my much smaller - sideways - but now bulkier - frontways - camera rucksack). So she wanted to set an example. And I started a scene!
You will rarely see me get angry or loud, very rarely.
But on that occasion I did! I had done EVERYTHING to avoid getting into problems, and suddenly she was telling me to return to the check-in desk to check in my CAMERAS?
"Never!" I replied.
"You must, it does not fit in here, so you can't bring it on board!"
"I brought it HERE on board!" I replied.
"Well, German rules may be different, from here you must check it in!"
"And I won't - over my dead body only!" I shouted. "I came in here only a week ago with the very same hand luggage, and left from here to Newquay with the same constellation of check luggage versus hand luggage, i.e. went on a domestic flight from THIS VERY airport, and a week ago I was allowed to bring my cameras on board and now I am not!?!? This is ridiculous. Silly it is!"
She went all uppity and said, "OK, pass, you'll get returned by the x-ray people, just you see!"
And I even went as far as to retort: "Just you see that I won't!"
And I wasn't!
But I fought with nails and teeth to bring that rucksack on board.
I say that in case you get yourself a real (quite rectangle) hard case with plastic foam linings into which all your gear can go, so that that case definitely meets with the size of those devices, you should be safe.
After all that ruckus I was really miffed to see what size hand luggage other people were still allowed to carry on board! Only was theirs rectangle ... :madass: (<- still - when I think about it).
Funny to imagine you angry :)
I know i would fight very hard myself not to check in my camera and lenses.
was that air berlin by any chance? i often go with them from stansted and never had any trouble (except them being late, very late ;) ).
hmm, if there is a guarantee this always works ... then it might actually be an option.. at least to get all thwe smaller items onboard on your body, and the rest using a rectangular container.
the firearm thing would in europe mean that you go to jail and not to your intended destination ;)
Yes, it was Air Berlin, but I had the trouble long before I ever got near the plane, you certainly know, where.
And yes, I was very late, too. Very, very late. Like over one and a half hours or so? My poor husband had to walk empty Hanover Airport for all that time waiting for me to finally arrive ....
That's the problem with airport security and personnel. The rules will vary from person to person and day to day. I've travelled around a bit with my camera gear in a Lowepro Computrekker AW...which is a little bulky, but not too big. A bag that size could hold all your stuff...except, I would think, the 300mm.
I think dgs has a good idea. If you have to, you can probably get away with 'wearing' some of your gear on you person. Probably best to keep the 300mm in the bag and just pocket the other lenses or body.
Alex, I've taken more than that on a plane in the last few months, but you will need to purchase a proper camera back-pack. (two SLR bodies, three L lenses, a hard-drive, and a ton of support gear like filters, chips, remote triggers, etc.) I have to mention though that it was long-distance international (LAX to FFM) and they usually allow bigger carry-on than some of the intra-European city hoppers.
If not, then you will need to buy a hard case to check it. To be honest, until the camera is yours, the manufacturer and distributors just pack them nicely and throw them around the back of a truck like any other box. A professional hardcase is just that - made to protect great gear. However,it's relatively expensive.
And as an aside, I would be more concerned about luggage theft by airport handlers than breakage. Make sure you get a plain black one, not a stainless-steel shiny one that might as well say "Expensive."
I have not traveled by plane with that much photo gear in years, but I would consider a Pelican, Halliburton or equivalent hard case and since such cases scream "expensive", consider placing it in a duffel bag or other inane nondescript bag. Goodluck and report back what you end up doing and how it worked out.
Thanks everyone! And from the responses I can see that this is not a fully resolved problem and probably is a pain for quite a few people.
I agree that it is possible! In fact I got all which i mentioned onto planes, but it might require being smart sometimes, or to flirt with the girl at the airline counter or whatever, in other words there never is a guarantee since it vastly depends on the person in charge of this. And as big mike said, what might be ok today, could be all wrong tomorrow ... you can really rely not on much here :(
True, definitely! But usually when I go somewhere, I have some short distance flight somewhere in my connection.
The big pain is also, that most of these smaller carriers have different restrictions regarding size and weight! And by now I think wheight will be my major problem ...
oh, yes, i know of cases where the luggage had been opened and was apparently screened for valuable items (apparently, since those items were missing afterwards).
Happened to a friend of mine on a connecting flight via Moscow to Japan.
well, my next flight is in a week from Germany to San Jose, and then a week later to the UK.
I probably won't get any container or whatever my solution will be in time, so I now decided to only take reduced gear for those two trips. Will let you know how it all works out and what my final solution will be.
PELI case, the only way to go. airlines are going to reduce carryon if they can. it speeds things up.
i carry 15k worth of cannon gear. i used to freak watching my gear go in the hold but with a PELI i know they cant do a thing to damage my gear.
i even used the case (with kit in) to support a 4x4 in the desert while changing wheels.
i know there are other cases out there but i only know my gear.
you get what you pay for;)
tom
