wolfercatt
- Joined
- Dec 9, 2012
- Messages
- 19
- Reaction score
- 1
- Location
- Richmond, VA
- Can others edit my Photos
- Photos OK to edit
OK..one more question. Can you explain the difference in a 100mm lens vs the say 70-300mm lens? I know there is a big difference, I'm just unsure of what it is. Thanks
The 100 Macro is a prime obviously, and is designed for very close, accurate focusing with maximum magnification. The 70-300 is a Zoom obviously, that is designed for general use. IT is NOT a Macro lens.... any Zoom that claims Macro capability usually means that it will do some lightwieght macro... usually around 1:3 (basically like 1/3 of a life size image). True Macro lenses do 1:1 (actual life size image). There are some actual Real Macro zoom lenses... but they are rare and relatively expensive.
Any Zoom can be turned into a fairly decent "almost macro" lens with tubes... but you have to deal with the increased weight and size, and the tubes connection makes it slightly more "wobbly" and difficult to use, but they can turn out good images.
Also keep in mind that in macro, lighting is everything. You can use natural light of course, but diffused flash will give you much better, more consistent images.
does that help?
That helps immensely!!! I do need a good flash and was looking to start with an SB-600 + Diffuser and a remote. Does that sound decent to begin with? Sharon shed some light that I'm not wasting money buying and trying because I can always re-sell the equipment. I went into this thinking I was throwing all kinds of money away by not knowing what I wanted. I had a Nikon L120...awful imo...it died just out of warranty. I then purchased a FUJI HS30 last week thinking I could get some macro with it. Not even close..so I returned it and bought the D5100. I'm very happy with this camera, but craving the macro Not sure how to get where I want to be, but you both are really helping me. I appreciate your time and insight!
