Help with making this into a stereographic projection
jdong217
This is my first try. Unfortunately it didn't occur to me to try and make this into a small planet until after I had taken it. It's unlikely I'll be able to reproduce this same shot with the same people ever again, which is why I'd really like to make this work.
Anyway, I'm just following a tutorial I found on google and I've got a really rough result. The problem is harsh edges and distortions. I'm sure there's a way to fix this but hwo do I go about doing it? For reference, here's the original image as well as the result:
Not sure what you're trying to do or why, but if you want the edges to line up, what you see on the left side of the image must match what you see on the right side. Generally, this requires a level image, which yours is not as it is tilted to the left.
I was aiming to have it look like a little planet. The buildings in the background would be on the surface of the planet and the railing/pavement behind the people would effectively turn into a really elevated platform
I gotcha, yeah, I bet if you make sure that rail is at the same level on the left and right side, you'll see major improvement.
For doing something "just for giggles," that's pretty talented.
