sk66
- Joined
- Jan 24, 2014
- Messages
- 244
- Reaction score
- 42
- Location
- Harrisburg PA
- Can others edit my Photos
- Photos OK to edit
If the image is underexposed it will appear "bluer"... IMO, that's your main problem. As for the WB setting, you can use a reference image of the white paper as "pre" (custom WB) or one of the settings in the camera that matches your lighting.It looks more like a metering/lighting issue to me.
You're photographing little reflective things on bright white... the camera is going to want to underexpose by ~ 1-2 stops.
This is the first image with only pushing the exposure 1 stop.
But if your lighting is constant (predictable) why are you using AWB when SOOC images is your requirement?
Not sure what you mean by this?
I tried using the PRE wb feature and it was turning my images even more blue. Not sure why. I made sure to fill the entire frame with white posterboard when I took it.
