How to save raw files?
hamlet
Belgium
Is it possible to save the changes i've made to my raw files in lightroom 5? I want to back up my raw files with the edits. Now when i try to copy the raw file to some other location and i import it in lightroom 5, none of the changes are saved.
JacaRanda
Hobbyist Birdographer
Orange County California
The changes you make to the raw file are saved in the catalog. You don't need to import it again into LR from the other location (if you do, you get the original raw file again). Just open the catalog that you made the changes in.
Lightroom catalog FAQ
OP
hamlet
hamlet
Belgium
So its not possible to save the changes to the raw files directly?
Josh66
Cedar Hill, Texas
No, you can't 'save as' .CR2 or .NEF or whatever.
OP
hamlet
hamlet
Belgium
That is not good. I'll have to edit my pictures from scratch if i ever want to move them.
Josh66
Cedar Hill, Texas
Just move the sidecar files with them. By default, they should be in the same folder as the RAWs.
In Lightroom, I think it's a .XMP file. It's basically an 'edit history' of the RAW.
JacaRanda
You could save your edits in a different file format like TIFF. Adobe Photoshop Lightroom 4 * Supported file formats
Or you could move or save the entire catalog to other places and there would be no need to edit from scratch once you re-open the catalog in LR. You could also go crazy and have only one photo in a catalog and what it seems like you want to do, without having to re-edit from scratch.
Lightroom works great for most anything if you have a desire to learn and use it.
OP
hamlet
hamlet
Belgium
I will figure this out. Thanks for the help.
Ysarex
St. Louis
This is very good. It's part of the whole point. A raw file is like a film negative -- you make a print from it but you never alter the original in any way.
Joe
OP
hamlet
hamlet
Belgium
Sure it is. But what would be better is if it could retain both the original and the edited within the raw file. Its not 1835 any more, the renaissance is long over john wayne.
The_Traveler
Completely Counter-dependent
Supporting Member
Mid-Atlantic US
Website
www.lewlortonphoto.com
All of the edits made in the raw file are saved.
There is a same name file with an xmp extension that contains all the edits.
Look in the folder.
That is called the sidecar file.
As long as that file is carried along in the copy process, all the edits are there.
And if you still don't understand, do a search for 'nef' and 'sidecar' and rread the extensive information available.
480sparky
Chief Free Electron Relocator
Supporting Member
Iowa
Website
pixels.com
The sidecar file is basically a list of what edits you did..... Adjust black & white points, induce an S into the curve, increase saturation, crop, rotate, etc.......
The next time you load the image into your editor, it reloads the original raw data, then performs those same steps again.
Josh66
Cedar Hill, Texas
You can. Very easily. Like I said, all of the edits are in the .xmp sidecar file. Just make sure that stays in the same folder as the RAW and all of your edits are intact.
It's basically exactly what you're asking for, but split up into two files.
KmH
In memoriam
Supporting Member
Iowa
Website
kharrodphotography.blogspot.com
What Josh said, adn get this inexpensive reference book - The Adobe Photoshop Lightroom 5 Book: The Complete Guide for Photographers
Or, open LR 5 and press your keyboard F1 key to go here - https://helpx.adobe.com/lightroom/topics.html
Lightroom doesn't actually edit anything.
Line commands in the .xmp file alter how the ACR algorithms display the image.
https://helpx.adobe.com/lightroom/topics/managing-catalogs-and-files.html
https://helpx.adobe.com/lightroom/help/library-module-basic-workflow.html
I also highly recommend getting The DAM Book: Digital Asset Management for Photographers
Dliwevad
The big thing people forget about RAW files are they are not image files but rather a raw "dump" of what the sensor was exposed to. That data must be interpolated first before it can be seen and manipulated.
Making adjustments to contrast or white balance could never be saved as RAW format because it doesn't exist in the data to begin with.
ClickASnap
