Here's what it looks like to me. Main light is high, probably on a boom stand, positioned at about 12:30 to 1 o'clock and just slightly in front of the model; that creates the under-chin shadow, the shadow under her breast on the right hand side of the frame, and it creates the eye catchlights. The bright highlights on the sides of her are created by two flash heads, positioned slightly behind her, and lower than her waist level. I would probably use 20 degree grids on those flash heads, and also fit each head with a barn door set, to prevent light from striking the lens front. You can tell that the side lights are positioned slighly behind her by the darkness (shadows) on her belly area and ribcage area, and by the fact that her jawline on the left side of the photo is "hot",yet no light strikes the top of her head,etc. The side-lighting on the right hand side looks like it comes from a flash head that is a bit higher than the one on the camera-left side.
The backdrop looks like plain gray seamless paper.
