syndicatedshannon
- Joined
- Jan 1, 2014
- Messages
- 13
- Reaction score
- 1
- Can others edit my Photos
- Photos OK to edit
I definitely don't want to restrict my daylight aperture with the off-camera flash equipment I'm buying. As you know, most current high-end consumer DSLR cameras have a maximum flash-sync shutter speed of about 1/250, meaning f/stops necessarily over 10 in daylight. So, I was doing some research on HSS.
I found these graphs of light amplitude from Canon HSS setups:
It looks like the amplitude is inconstant enough to cause some banding at the expected resolutions. Is that true?
Are there flash units that have constant-duration adjustable power output, without that charge-bounce symptom? If so, what keyword/distinction would I look for when purchasing?
