Authentic Southerner
- Joined
- Feb 16, 2015
- Messages
- 81
- Reaction score
- 45
- Can others edit my Photos
- Photos NOT OK to edit
I have read and read on this topic until I am I think more confused than when I started.
Here is what I know. The Voigtlander 15mm is a great lens, I plan to use it on my Minolta CLE rangefinder. I have the shoe mount accessory viewfinder to assist with framing the ultra-wide shot. I understand that the 15mm lens has a very broad depth of field and that most say...Set it at 2 meters and f4.5 -f5.6 and you will be in focus from about 2 meters/ 6 feet to infinity.
Without a complex understanding of how to calculate the hyperlocal distance I hope to find out if that general assertion is true ? i.e. set at 4.5-5.6, focus to about 2 meters, shoot and don't worry....
Also I notice on the focusing distance portion of the lens that the distance (on the actual lens markings) between 2M and Infinity is about 1/4 of an inch (very close) and I also notice that the distance between 0.3M and 2M is about 2 inches...
I take that to mean that close focusing, between 1 foot and 6 feet is much more critical than distant focusing between 6 feet and infinity ? Is that a fair understanding ??
Also at the base of the lens I see fixed markings .... white dot in center...4.5 -- 16 out to right and left from center dot...these markings are just behind the rotating distance focus ring...
I will take a pic with my phone and attach so it will make more sense...
I don't have the mathematical mind to deal with off the cuff calculations and honestly don't want to invest the brain power to understand the science of the concept, honestly I just want to know what to do as a general rule and how changing focus distance nearer/farther will shift the range of depth of field... If I can get the general concept I think there is enough "slop" in a 15mm that I won't have to worry too much about fine details.. Thanks in advance for input...
