trevortdogr
Is the 50mm f1.8 G better than the 50f1.8D?
Yes - much better. Do not buy the 50mm f/1.8 D.
I will be shooting portrait, landscape.
The 50 1.8G will be decent for portraits on a DX. I still think the D7000 kit lens - 18-105mm - is good to start with. A good walk around lens with decent range.
Use it till you learn the camera and can see what you shoot the most. Otherwise you're just throwing money at what you think you want rather than what you need.
The 24-120 f/4 is good, but really not wide enough on a DX if it's your only lens - and it's $1200. You'd be better saving the cash and adding the Tamron 70-300 and a used SB600 or an SB700 speedlight at some point.
That would give you off camera flash, a fast prime, and you'd be covered from 18-300mm. If you really don't want the 18-105, then the 16-85 is twice as much $$ but is better build quality (and marginally better image quality).
The 16-85 is a better lens, but the 18-105 is a better deal when bought with a body.
My 2 cents.
I did look at that 24-120 and that is more than I want to spend for glass right now.
I can get the 18-105 with body for $1500, or the 18-200 vr & body for $2050. I will probably get the 18-105 & body, I don't want to spend that much since the wife really wants to get a 50mm for sure and I will get that for sure with 1 other lens.
What is better a 35 or 50, help me to understand why one is better over the other or does it come down to preference?
Sleist thanks for your help.
