- Joined
- Jul 3, 2004
- Messages
- 3,714
- Reaction score
- 531
- Location
- Here N There
- Website
- img24.photobucket.com
I am currently looking to update my 70-300mm range. Right now I have the AF ED version, which is rather terrible by D700's standard.
I was initially looking at the 70-300mm VR and was then being recommended the 28-300mm instead. Initially, I was only thinking about the 70-300 range, but realized that now it's much more than that.
Comparing the 70-300mm range, the 70-300mm VR doesn't seem to have noticeable advantage over the 28-300. Ok that's good!.
Then I am looking at my current lens.
F1.4 50mm
F2.8 20mm
F2.8 35-70mm
F2.8 105mm
I don't bring 50 and 35-70 together. It's either or. I am happy with both lens. I take the 50mm for street photography, but will take the 35-70 for events. If I get the 28-300, for event wise, I will just bring the 20mm and 28-300mm. Two lens does it all.
If I am traveling(may run into all sorts of shots), I will take 20, 50, 105 and 28-300. Weight wise I am not saving any in this set up.
Essentially, it will replace both my 35-70 and 70-300.
The 28-300 is a lot more expensive than the 70-300, but if it really is as advertised and that it makes sense for me, then that's not a problem.
The only thing I may mind is the loss of IQ in the sub 70mm range compared to the F2.8 35-70. If it's not THAT bad, I wouldn't mind either.
So what do you guys think? Is the 28-300mm VR for me?
F1.4 50mm
F2.8 20mm
F2.8 35-70mm
F2.8 105mm
