A very DARK piece of card placed very close to the edge of the glass could help to darken the edge of the glass, through what's commonly called subtractive fill; I think that might be what Braineack was thinking when he mentioned flags to help the glass be separated from the background. No matter what he was talking about though, the issue that concerns me is that it seems that the background is where ALL of the light is coming from...I do not see a source of front lighting, so the effect is of intense, blinding back-lighting...I just do not think that's the best way to light this product. I think you need some source of light coming in from the front-side of the glass.
The problem here, as has been pointed out, is that you are trying to shoot a white powder against a white background. While shooting white on white is done all the time, in this case it's going to reduce the visual weight of the powder, making it a much less dominant element in the scene.
If shooting this on white is a must however, I would recommend changing up the tactic a bit. First, frame the scene. Use a longer focal length, like a 100mm or so. Use a low camera angle to help give a dramatic presence to the glass, rather than looking down on it, which diminishes it. If you are using a flat surface and separate wall for a background rather than a sweep, this will also bring the horizon line down below the bottom of the glass, rather than through the middle of it. Once you have the scene framed, mask off any area of the white background that isn't in the frame. Aim a light on the background and meter it about 1.5 stops above your exposure settings. Now you should be ready to turn off the ambient light and take a test shot. If everything looks good mark the location of the glass and start your pour shots. You may need to place a reflector to light the powder as it pours. After each pour, empty the cup and do it again until you get the shot you are happy with. Now you should have a good shot of the pour and a good clean shot of the glass to work with.
