LR won't import photos, help pls
Rob5589
Well after several restarts it is working again.
LR will not import, it says "no photos found" when clicking on folders that have photos. Will not import or "see" pics on SD card either. I have restarted to no avail. Was working fine until last update couple days ago.
Any ideas...?
Thanks
dannylightning
Akron Ohio
your sure the files in in a format that light room recognizes or have you changed any setting that would effect that.
if that is not the case can you roll back the update to the old version
only things i can think of.
