Marius:
Here's 2 good tutorials from Mark Wallace about light meters and ratios. These are great vids to get you on your way.
Digital Photography 1 on 1: Episode 10 - YouTube
Digital Photography 1 on 1: Episode 11 - YouTube
You have ONE BIG problem: You wrote: - we have a model and 2 light sources
- model is facing the camera directly
- lights are on both sides in front of the model, facing the model at 45 degrees
- both lights provide the same output (flat lighting) and need to be converted for a 1:2 portrait lighting
Okay...the problem is that the two lights are going to basically cancel one another out if they are left at the same distance. This is a terrible way to light...two lights, equal power, and equal distance, aimed in at the subject at 45 degrees....ummmm....that's kind of like a copy stand lighting setup where the goal is perfectly flat, even lighting with an exact 1:1 ratio....TOTALLY FLAT, totally EVEN lighting.
What you ought to do is angle the MAIN light in at the subject from 20 to 50 degrees,depending, and then aim the FILL light straight ahead, from a position right NEXT to the camera.
gsgary, sorry, but this is not what i asked. This was just the most simple example i could come up with.
Basically your fill light will be 1 stop lower than your main light, do you know what a stop is ?
Marius:
Thank you, Tee. Mark is an excellent teacher, i'll definately need to have a look.
Forgive me, you have me really confused-not a tough thing to do at this point on any given morning...So that the light from other sources isn't affecting your measurement.
Do you actually have a meter or are you using the in camera meter?
What exactly does the assignment read that you have to do?
What are the settings on the back of your lights? They should easily tell you what the output is and you should be able to set the ratio according to that.
Here's a tutorial that may also help you a bit: Portraits with Two Lights: Adding a Fill Light
Then there's no need to remove the dome then as i only have one light source at a time when measuring them individually.
There is no assignment whatsoever, i just wanted to know where to point the meter when measuring individual lights ;] And yes, i do have one
I know there's settings on the lights themselves, but imagine that the're ain't - my method would work in both cases. The only problem is that it's a little more difficult than looking at the output values on the lights themselves.
Thanks for the explanation about the dome - makes sense now
How is there no settings on the lights you are using? If there is no settings, you can't adjust the lights, so there is no way to create the ratio unless you use two different powered lights...
I could be over-simplifying things I guess... Or totally off base...
Hello,
Since google gives me too conflicting results, i've decided to ask this question here. Let's consider a simple example:
This is where i get a bit confused with metering. Let me tell you what i would do:
- set a meter to 1/160 at iso 100
- turn on the left light
- put the meter next to the model's right cheek, turn it towards the light and take a reading
- let's say it metered f4.0
- now switch to the right light and take readings while adjusting power output to get f5.6
- turn on both lights
- put the meter next to the center of model's face and turn it directly towards the camera
- take a reading for final exposure
Yet something feels wrong to me here. Is that a correct way of doing it? I guess the main questions are:
a) do i turn the meter towards the light source when measuring individual peimar lighting?
b) do i place the meter at the relevant part of the subject's face when measuring individual lights or should it always be in the same position?
c) do i even need to calculate the "final exposure" or should i use the one from the more powerful ligh source?
Thanks for your advice
