- Joined
- May 11, 2005
- Messages
- 5,787
- Reaction score
- 97
- Location
- Houston, TX
- Website
- jwdphotography.com
I don't really like Celcius, though...maybe we should all switch to Kelvin.
<snip>
Also: We (the US) need to just go cold turkey and scrap the imperial system. THere would be measurement confusion for a few years, but eventually we'd be able to communicate to the rest of the world without converters...
There is a little problem with pound-mass. Take this for example.
You can find this all over the net, but the convertion between pounds mass and kilogram is 1 lbm = .45359237 kilograms or just 1 lbm = .45 kg. Now we can find that force in Newtons, we get .45*9.806=4.4127 N. We then can convert this to pounds-force and that convertion is .224 lbf/N*4.4127 = 1 lbf. Now that we had this in force we should be able to divide by 32.2 ft/s^2 to get mass but now we are left with a mass that 32.2 (.0310559) times smaller than what we started out with. Basically, when you are converting between metric and SI, you would be able to go from mass (SI) to force (SI), force (SI) to force (metric), force (metric) to mass (metric), mass (metric) to mass (SI) and still come up with the same number you started out with. But with this, you can't...
Purely metric here.
Can't make head nor tail out of baby measurements when the babies were born in Britain, the States or Australia. Neither weight nor length. All I can ask back is "Would that be considered 'normal'?" When the answer is "Yes, pretty average", I get the idea.
I have more of an idea of what temps in Fahrenheit are as compared to our Celsius-grades. But once we enter the field of cubic measurements, I'm totally lost when someone gives me an imperial measurement.
Good one, it's the same here. I forgot about that one.On the baby thing, we still measure babies in pounds at times. But its seems everywhere to get that baby out, the mum to be needs to be 10cm dialated, not 4 inches.
I hadn't seen that before but it is quite funny, and it shows how an inconsistent set of units can lead to gross misunderstanding.
The conversion from lbm to lbf is
lbf = lbm x ft/s2 / 32.2
As often happens, inconsistent units require constants where a consistent set does not.
Slugs, lbf and ft/s2 are a consistent set:
lbf = slugs x ft/s2
Kilograms, newtons and m/s2 are a consistent set:
N = kg x m/s2
Now, put the formula
into the little 'problem' and no matter how you calculate it, it always works out correctly.
Best,
Helen
Which means that on earth like I said a couple of posts above lbf and lbm are the same value:
lbf=lbm*32.2. ft/s^2/32.2...
Different units but they have the same value...
How is Architecture taught in other countries outside of the U.S? Just curious....
