- Joined
- Jan 2, 2007
- Messages
- 3,248
- Reaction score
- 3,729
- Location
- Cali, Colombia
- Can others edit my Photos
- Photos NOT OK to edit
I wonder at what point mold inside the lens begins to affect image quality.
You're welcome. BTW: don't let the mold continue to grow. I've read that you can kill the mold with UV light. Sunlight might do it, but don't let the lens get warm. Maybe a UV lamp would be safer.Thank you Designer, good info.
It wasn't me, but if anything, I would caution against any DYI lens repair.I 've heard you cab stop it growing with sunlight but not make what's there go away. I've also heard (maybe from you a while back) that Canon won't clean a moldy lens because they can't guarantee the work. I'm going to look into a large container that I can fit camera and lens into with silica gel.
Could you not put them in a suitcase? Just buy twice the quantity of silica gel that you need and regularly dry the half that is not in the suitcase in the oven and then change it?I 've heard you cab stop it growing with sunlight but not make what's there go away. I've also heard (maybe from you a while back) that Canon won't clean a moldy lens because they can't guarantee the work. I'm going to look into a large container that I can fit camera and lens into with silica gel.
Can't you buy them in Colombia? I know it can be complicated there but it should be possible.Thanks Dave that is a good idea. I'm going to buy a quart of silica beads when I visit the states.
How does such an old lens compare to the modern ones? Does it work with DSLR?I have a Canon 500mm Mirror lens that got mold inside the front element back in the middle 1980's. I let it get a little sun and the mold died (it stopped growing) and it's been the same ever since. The mold has had absolutely no effect on the pictures that I've taken with it. It's been stored in a camera bag with all of my other lenses and they have not been effected by it.
