If these are sizes in inches and ppi here's what you have.
Images are
2.056 x 2000 = 4112px
1.416 x 2000 = 2832px
So 4112 pixels x 2832 pixels in size which is pretty big!
There are 3 simple equations that help give you the info you require.
No of Pixels (on one axis) (Px) = Print Size (PS) x resolution (ppi)
PS = Px/ppi
ppi = Px/PS
From this you can work out print sizes or resolution for a particular print size so as you can see with the No of pixels you have you can easily get a top quality 13" x 9" image (or smaller) at 300ppi and you can get larger sizes up to around 16x12 at 240ppi (which will look fantastic).
And you can print even larger if you wish.
One other thing, are you looking at the print with the border at the pixel dimensions you quoted?
Thank you... I copied this so that I can use these figures.. !!
Yes. :meh:
w= 1.416
h= 2.056
Resolution = 2000
Is not a good res. ? what sould i shoot for?
Prints should be no higher than 300ppi for up to around 10x8 (slightly larger with an 8Mp+ Camera) so that is 3000 pixels x 2400pixels. Depends on res of your camera.
Zendianah, I don't know how you set up print size in relation to dpi in your program. But in photoshop, you can recalculate these numbers by going into the Image Size dialog, then unchecking the "Resample Image" box, and set Resolution to 300 dpi. That should give you the approximate width and height (Document Size) at which you can print your image at high resolution. In this example, I can print my image at 11.6x7.7 at 300 dpi with no loss of quality. And as JD mentioned, if you drop your dpi down to 240, you can print an even larger size image at high resolution with outstanding quality. For you, with pixel dimensions of 4112x2832, it will be quite a large document size.
NJ
NJ
THe only thing I'll correct you on is your use of the dpi term. Note above in photoshop it uses the term pixels/inch (ppi). dpi is a printer/scanning term for the number of dots per inch an image is printed (or scanned) at.
As digital images are made up of pixels, the correct term is pixels per inch (although I know many use the dpi term meaning the same thing).
THe extra pixels in the image I think are down to the white border that was added and you may find the tifs exported without the border will be nearer to the size you showed (my images are this size from my 20D)
