Nikon VR explained
The first and most important rule of VR is this: never turn VR on unless it's actually needed.
Rule #2: VR should normally be off if your shutter speed is over 1/500.
Image stabilization should usually be turned off, even when the camera/lens is being used had-held.
VR/IS/OS is basically useless when shutter speed is quicker than 1/500, and is not the universal panacea many make it out to be.
Good camera holding technique is all that is needed for focal lengths up to 200 mm, unless shutter speed needs to be significantly below 1/the focal length of the lens.
Da Grip « Joe McNally's Blog
Nikon VR explained
Wow guys, you have all been most helpful! Those pics up there, the colors look different in each, that can happen from lens to lens, no? I do notice that the edges are blurry in both pics, probably from having the f/stop wide open? So, the VR should be turned off? That doesn't make sense, interesting! I did shoot some from the back of the room with that Nifty 50 and they turned out not so nifty. Not sure why but they were out of focus. I think camera shake may have played a part, idk. Maybe I am not holding that big Nikon right. But the ones from the back of the room with that looked crappy. I would like more zoom. I will go to that church and take some measurements to see how much zoom I would need. I may look into that 85 1.8 and the 35 1.8. Definitely an option. I am thinking of getting the 24-85mm f/2.8-4D IF, since one can still buy it new on the Nikon website. It's like 750 bucks. Is it true that 80-200 was made in 1986? Oldie! Though I am sure not all of them are that old, depending on which one you'd buy. Also, according to Ken Rockwell, he said not to bother using the 80-200 on a DX body due to that it won't autofocus on the DX bodies, is that true? Or is he full of bologna? So far, I am leaning towards getting the 80-200 and the 24-85. I'd like to get the later new from the Nikon site..but may be over budget.
I have a question? I've heard of pump focus, what is that? Is that on the 80-200? I guess the d7100 must have the screwdriver connection for this lens? Yes? Also, one last question, I am all new to auto settings, I shot with an all manual film cam before. For these indoor events, should I use shutter priority you think? Like SP for the zoom and AP for the portrait type shots?
Thanks again guys!!!!
The beauty of the D7100 is that it comes with a built in AF motor. So it can AF most if not all Nikon lenses vs your typical DX camera.
When an AF-S (or AF-I) lens is mounted, the Silent Wave AF motor in the lens is used, not the AF motor and screw-drive in the camera body. AF-S lenses do not have the mechanical connection to the screw-drive that is needed to drive the lens AF mechanism.
The in the camera AF motor and screw-drive is only used to drive AF lenses.
Thanks. Still leaning on that 80-200 and that 24-85. But maybe I should get two prime lenses? That 35 1.8 and the 85 1.8? I will have to measure, make sure I will have what I need, thanks a lot guys. One question, there are older 80-200 mm? Does anyone have a picture of the push pull and the more recent ones so I know what to look for? Thanks!
You have helped me more than the two other forums I was asking this stuff on! Thanks!
