Need help
Discussion in 'Canon Cameras' started by CODYMAJ, May 20, 2019.
  1. CODYMAJ
    CODYMAJ TPF Noob!
    Feb 19, 2019
    39
    15
    Virginia, USA
    The other day I had decided I was going to save up some money and upgrade cameras. Found out what I could get for my current, so I had an amount I was aiming for to save. Went out for a shoot a few days later and it happened.
    Err 20.
    I have tried every home remedy that I felt wouldn't worsen the error to no avail. I now have a dilemma.
    Do I pay the 200-300 (based on internet research) to fix the error to be able to sell it as a functioning camera, or do I sell it for "parts" or as a non-functioning camera and pay more out of pocket to upgrade? Any advice would be highly appreciated.
    The camera is a Canon SL2, the camera I am looking to get is a Canon 80D
  2. Original katomi
    Original katomi No longer a newbie, moving up!
    Mar 27, 2019
    351
    100
    There is a site rescuedigitalmedia.com
    They say that err 20 is a mechanical problem how old is the camera
    Hope this helps
  3. CODYMAJ
    CODYMAJ TPF Noob!
    Feb 19, 2019
    39
    15
    Virginia, USA
    That site seems to be for photo recovery, which is not what I need.
  4. Derrel
    Derrel Mr. Rain Cloud
    Jul 23, 2009
    43,767
    16,661
    USA
    Ahhhh... Canon's dreaded Errr 20...
    Is the LENS a genuine Canon? Err 20 is a very non-specific error, and doesn't tell you much. It could be a number of things...maybe the battery contacts are providing just a tiny bit too little current; maybe the body contacts do not "see" the lens... removing the lens and battery for five to ten minutes is a first check.
    My vote? for $200-$300, fix the camera,and then immediately Sell it.
  5. CODYMAJ
    CODYMAJ TPF Noob!
    Feb 19, 2019
    39
    15
    Virginia, USA
    It is very no-specific indeed.
    The lens is indeed a genuine Canon, I only own canon lenses in my small arsenal at the moment. So that box is checked.
    I have removed the battery for hours, but not the lens. I could try that.
    All else fails, I appreciate your vote, I'm leaning toward that route too.
  6. Soocom1
    Soocom1 No longer a newbie, moving up!
    Feb 27, 2006
    1,290
    340
    Southwest US
    Which lens?
    I have a similar issue with my 35-350 that pops up only under certain circumstances.
    if its an older lens on a newer body, thats half the issue there.
    • Like Like x 1
  7. CODYMAJ
    CODYMAJ TPF Noob!
    Feb 19, 2019
    39
    15
    Virginia, USA
    The lens that was on it when it happened was a 16-35mm f/2.8 II, but the same issue occurs when I have my 50mm on as well.
  8. Soocom1
    Feb 27, 2006
    1,290
    340
    Southwest US
    That sounds like camera specific then.
    The 16-35 is a newer lens. it should work fine on the newer level EOS bodies.
    If the 50mm is part of the kit, then yes the body is the issue.
    • Like Like x 1
  9. Original katomi
    Mar 27, 2019
    351
    100
    Ok no probs
  10. smoke665
    smoke665 TPF Supporters Supporting Member
    Mar 29, 2016
    9,934
    4,392
    Alabama
    A quick search found used models of your camera out there from $380-$425 range. If your intent was to keep the camera then paying $300 for repair would be in the neighborhood of 70-80% of the cost of replacement with a comparable used model but you'd know the camera. However if you intent is to upgrade anyhow then you'd be risking $300 in the hopes of gaining $80-$125 if/when you sold the camera, not the greatest of return on your investment. I ran into a similar dilemma a couple years ago with a body, and elected to use the money I saved on the repair, toward a new body.
  11. CODYMAJ
    CODYMAJ TPF Noob!
    Feb 19, 2019
    39
    15
    Virginia, USA
    I ran the numbers a few times myself, but I'm sure my bias was giving myself the best case scenario. I needed to hear the cold facts, and you put it out there well. Thanks.
    I reached out to Canon and they have a upgrade program that I might look into. Essentially, they take my Err 20 product and fix it and sell it as a refurb, and then sell me a discounted refurb. However with my lenses, I am able to look at a body only kit and save a lot of money already, so if the refurb discount isn't much, I may just do as you said and use the repair money toward a new body.
    Thanks for the response.
    • Like Like x 1
