I found prices for the UK (from www.warehouseexpress.com):
E-P1 + 14-42mm f/3.5-5.6 £699
E-P1 + 17mm f/2.8 £749
E-P1 + both lenses £849
A bit pricey...:meh:
i agree, seems a little overpriced
According to Canon the 1D had an electronic shutter.
I'm still missing what's new from this new camera. I'm probably just being dense, but can you highlight the "truly" new technologies that differ from other cameras on the market?
...I'm still missing what's new from this new camera. I'm probably just being dense, ...
You're only getting half of it. It has both. When it's syncing at 1/500 it's not using its mechanical shutter. If you read the specs carefully, you will see it has both an electronic CCD shutter and a mechanical shutter for things like blub mode. There is no way a mechanical shutter is moving fast enough at 1/500 to avoid being caught by the flash passing the sensor.By electronic shutter, I do not mean that the speed of the shutter is controlled electronically as the Canon website suggests. What I mean is that there is no "physical" shutter at all. The shutter itself has no physical moving parts but done within the CCD. The image you included clearly indicates a "Vertical Focal-Plane Shutter" which means there is still a physical shutter. Dpreview's 1D review has a picture of the shutter mechanism which they mentioned is a borrow from the 1V film body. I used to own a 1D and you can physically see the shutter opening and closing.
Technical Hall - Technical report 2001.12Feature 13: Ultra-fast electronic shutter with 1/16,000 sec. maximum and X-sync at 1/500 sec. The EOS-1D uses the electronic shutter integral to the CCD sensor together with the vertical-travel, focal-plane shutter (see Photo 1) controlled by rotary magnets. All shutter speeds, from 30 sec. to 1/16,000 seconds are controlled by electronic charge accumulation ON/OFF switching of the image sensor (the focal-plane shutter is fully opened immediately before the electric charge accumulation and closed immediately after completion at maximum speed of 1/125 sec.). The focal-plane shutter covers and protects the CCD sensor during standby, and controls the length of bulb exposures.
Photo1 Shutter unit The X-sync speed of 1/500 sec. is also controlled by the duration of electric charge accumulation of the image sensor after the focal-plane shutter is fully opened. Flash sync uses an electronic X-contact that is more reliable than a mechanical one. The focal-plane shutter, designed around the EOS-3 shutter unit, eliminates the high-speed shutter control elements to slow down the shutter speed to reduce mechanical load, achieving a durability of 150,000 shutter-release cycles.
In one word, Yes. In more words there is a reason only lower end cameras (P&S, D40, D70), and cameras which existed very early in the DSLR development (1D) have electronic viewfinders. CCDs suffer from blooming effect where by the quality of the results drops when light hits the sensor during read out. It is possible that so much light can hit it that artefacts actually form on the image which leads to a lot of people photographing a sunset assuming their camera was in some way broken.usayit said:Do we really need a physical shutter?
...Nothing in this camera design couldn't have been done in film.
