- Joined
- Mar 8, 2011
- Messages
- 25,160
- Reaction score
- 9,010
- Location
- Iowa
- Website
- pixels.com
- Can others edit my Photos
- Photos NOT OK to edit
I still don't have my 50mm 1.8D and don't exactly know how aperture ring will work, and from your answers it became very confusing to me how exactly aperture ring will change aperture when mounted at reverse and what will cheap or nikon reverse ring will help me in setting aperture exactly? Please can you explain me?
The reversing ring has NOTHING to do with the aperture setting. Nada. Zip. Nil. Goose egg. D lenses have an aperture ring. When you reverse a D lens, you simply unlock the aperture ring and dial in (using the ring, not the command dial on the camera) whatever aperture you want.
When a D lens is removed from a camera, it stops down to whatever aperture it is set to. Usually, it's the minimum (and locked there) because it needs to be set there for a DSLR to work. But if it's dialed in to f/8, when you remove it from the camera it sill stop down to f/8 and stay there. When you installed it reversed on a camera, the viewfinder is dark because it's at f/8. Using a BR-6 will open it to f/1.8 so you can focus & compose, then push the little lever on it and the lens will stop down to f/8, or whatever aperture you've dialed in on the ring.
And which reverse ring will be batter cheap or nikon? And how? Provide any link if there from which i can read in detail.
I use a Nikon BR2A simply because it's damned solid. Fine piece of machined metal. Cheepies might even be plastic!
