This guy pretty much says it all
You always promote that lens! You must love it to no end.I can't afford it. Besides, I'm still in love with my $90.00 refurbished AF 50mm f1.8D!!!
not really, he's just whining about something he doesn't understand, and the guy can't even pronounce homage correctly or edit his video so we don't have to look at his computer desktop behind the video the whole time...
however I do agree that I would have much rather seen it as a f1.2 (if for nothing else but the cool factor), and it is very expensive for a 50-60 f1.4 lens when compared to others out there, but there is a reason for that.
there is a hell of a lot more to look at in a lens than just the speed and focal length. the 50 1.4g is a decent but not an overly phenomenal lens by any means, there are quite a few areas that the 58 appears to be superior to the 50 (judging from data and info from nikon).
The MTF on the 58 is improved across the board from the 50, which although its a mild to moderate improvement will result in a higher resolving, higher contrast lens
The 58 has nano coating, the 50 does not
The 58 has multiple aspherical elements, the 50 has none, even the recently announced Zeiss 55 Otus only has 1 and that thing has an MSRP of $4k and no AF (the Asph elements are likely why the price is so high too)
the 58 is well corrected for coma, astigmatism, and other aberrations. the 50 has moderate to minimal correction for various different aberrations
Due to the much better correction of the 58, it should exhibit significantly better bokeh, especially at wide apertures
Nikon claims that light falloff with the 58 will be minimal even wide open, the 50 has a fairly significant amount of light falloff until around 2.8 (in fact according to nikon, this is why its a f1.4 and not 1.2, as they wanted something they could make to have significant gains in transmission across the board, wide open, which would be much more difficult and expensive at f1.2 for only a 1/3 stop increase)
the 58 is a very specialized lens, if you're shooting wide open or close to it need the optical corrections that the 58 offers, than the 50 just won't cut it at all...in fact your ONLY options in that case would be the old NOCT if you're able to find it which has no AF, and no body CPU connections, and costs upwards of $3k used...or the Zeiss 55 f1.4 Otus which was recently announced, has no AF, weighs 2lbs, and costs $4k new...or the 58 1.4G which has AF, full CPU connections and functionality, etc and costs roughly half than the noct or otus at $1.7k. While I'm not really looking at getting one or anything, it does fill a niche need in nikon's lineup that really hasn't been available since the noct was discontinued in the mid 90's...I suspect they announced it specifically right now to possibly siphon off some sales from those who are looking at the also recently announced Otus from Zeiss (especially since the Zeiss was announced earlier, and is not shipping until mid november, when the 58 should be shipping a few weeks earlier at less than half the cost)
so if people don't fall into that catagory and are looking for a normal fast prime, then yeah a $1700 normal lens is a bit excessive, and the 50 1.4 or even 50 1.8 would be a better choice.
