Nikon D90 -no exposure on the file
Jubowa
The camera seems to take the shot just fine, it focuses, the mirror goes up, there is no error , but the exposure is black. I have shot in both RAW and JPG and there is nothing but a blank black. I have had the camera functions all checked out and everything seems to work mechanically. I have changed lenses ...... no luck. It is at only about 1/10 of normal shutter count. I have opened the RAW file and increased the brightness to max with nothing showing up in the file. Does anyone have any ideas? Thank you!
tirediron
Watch the Birdy!
Staff member
Supporting Member
Victoria, BC
Website
www.johnsphotography.ca
What do you mean by 1/10 normal shutter count?
Could you post the full EXIF data from one of the files?
OP
J
Jubowa
A little more info...... I have tried exposures in all modes, manual, auto, prog and various scenes. It was in landscape mode when it stopped working. One shot was fine, and the next was black.
tirediron
Watch the Birdy!
Staff member
Supporting Member
Victoria, BC
Website
And no error message on the display "Err00X"? Have you tried other memory cards and a two-button reset?
OP
J
Jubowa
Tirediron, I don't have the camera with me. I will certainly send it asap.
What I meant was, the shutter count on the camera is very low, only about 10k.
OP
J
Jubowa
Yes, I have change out the cards and done a two button reset. No change
xenskhe
Check the camera isn't set on a very fast, manual shutter speed, and/or the lens isn't stopped down to minimum aperture.
DarkShadow
Birdographer
Supporting Member
Connecticut
Darn that lens Cap. J/k I have never heard of all solid black.Change Cards maybe.
astroNikon
'ya all Bananas I tell 'ya
Supporting Member
SE Michigan
If you shoot with the lens off can you see the shutter open after the mirror goes up ?
KmH
In memoriam
Supporting Member
Iowa
Website
kharrodphotography.blogspot.com
A low shutter count doesn't mean much if the camera has not been stored properly.
With no lens attached you'll see the blinking F-- error code. Ignore it and trip the shutter as you watch the mirror go up and back down.
Set a slower shutter speed - like 2 seconds.
If the shutter opens and closes, the image sensor is likely dead, but you should then get a blinking Err error code with no number -page 256 of the D90 User Manual.
wfooshee
Does Live View show an image?
