Fox_Racing_Guy
- Joined
- Apr 17, 2009
- Messages
- 211
- Reaction score
- 24
- Location
- Canton,Ohio
- Can others edit my Photos
- Photos OK to edit
You can purchase the new SanDisk 280MB/s cards right now direct from SanDisk SanDisk US Online Store
Hmm... doing a bit of research here, the new card is based on the UHS-II standard, whereas the D5200 is rated as UHS-I compliant, so I'm wondering if you'd really see the speed benefit to the newer card using the camera's older card slot or if their might even be compatibility issues. I would imagine the would probably make the card to understand the older UHS-I standard but the UHS-I I think is only rated for a top end speed of 104 mb/s.
Yup.. going to have to do a bit more research here.
Well you might want to hold off actually, been doing some more reading and it sounds like the UHS-II format is not backward compatible with UHS-I, so from what I'm reading I don't think they would be compatible with the camera. I haven't confirmed it for certain yet but that does appear to be a real possibility.
When you look at the cards, you'll notice a new pin layout to support the UHS-II bus interface. While the typical row of SD card pin connections are still present, there is now a second row of pins used exclusively to read and write UHS-II signals. The first row of connectors is still used for normal speed, high speed, and UHS-I signals, meaning the cards are backwards compatible with all SDHC/SDXC host devices, albeit without UHS-II performance.
I've got one 64 GB and one 16 GB - honestly the 64 GB Is more than I can generally fill in one day, and since I transfer everything off as soon as I get home I haven't needed much more than that at this point. Wouldn't buy anything other than the Sandisk Extreme Pro though myself. Just makes a huge difference over the standard 30-40 mps Class 10 cards.
Generally fill in one day? Are you shooting video too?
ya had to poke the bear,didn't ya??
Upgrading to this card has made a world of difference in the speed it takes for my camera to save both RAW and JPG formats.The card is fast and allows me to shoot at high speed without worrying about the buffer slowing me down. What a difference the data transfer rate of this card can make.
Finally got my Extreme Pro in.
Measurable results:
fwiw, if I shoot on JPG - FINE, I can hold it down indefinitely with the Extreme Pro. Those RAW files were 26MB each.
