tedisme
- Joined
- May 2, 2013
- Messages
- 12
- Reaction score
- 3
- Location
- Portland, OR
- Can others edit my Photos
- Photos OK to edit
By the way, I'm moving towards recommending two bodies, a crop and a full frame (probably 7D and 5D Mk III) which bumps the EF-S lens out of the ranking. I'm still considering the 70-200 F/2.8 (probably the IS II version) with the often-combined 16-35 2.8 II OR the 17-40 F/4. The tradeoffs between those last two are pretty obvious: speed versus range. I still expect to have need of a good wide angle lens and a 7D's crop would make that 16-35 more like 56mm on the long end. My config would therefore be a 7D with the 16-35mm and a 5Dmk3 with the 70-200, which I think gives me good coverage. (I can always swap those two lenses to instantly get both a wider and longer config!) How does this sound? Am I missing something major? (Also, I need to get rubber rings for shooting through glass.) Edit: I can also buy a teleconverter if needs be.
