fwellers
- Joined
- Nov 21, 2008
- Messages
- 440
- Reaction score
- 6
- Location
- Northern VA
- Can others edit my Photos
- Photos OK to edit
Just have some beginning type questions about using flash on my pretty new dslr.
1) Just bought an sb600 speedlight for my Nikon D90. It has been my understanding, when using the onboard flash, that if I set the flash compensation value to some negative number, it in effect makes the flash less bright, and can take some of the harshness out of the shot.
Is that right ?
2) And if it is, I see that there is also a flash compensation setting on the sb-600. If I'm shooting with the speedlight in either TTL or even in Command mode, is that setting slaved to the onboard flash setting, or are each of them doing their own thing ? IN other words, can I set the flash cv to -3 on the body, and to some other value on the speedlight, and they will both fire according to their individual settings ?
3) Can the sb600 be forced to slave off of the cv that is set on the body ?
On another note, maybe I need to do some more practicing, but it seems that when if I use flash, my exposure indicator goes off the charts to the right ( overexposed ). Even when shooting on a gray day, I thought to turn the flash on for 'fill lighting' but it seems like I have to dial the shutter real fast or the aperture real narrow to get the meter to be zero.
Does that sound right or am i doing somethign wrong/missing something ?
Thanks for your advice.
Floyd
Is that right ?
Floyd
