Reassembling an Argus C3 rangefinder
fischer123
San Jose, CA
<br><br>&nbsp; There must be a trick to this. I removed the rangefinder from my C3 to clean it. As part of the dis-assembly, it is necessary to remove the exposure counter on the top of the camera. Unfortunately, the shaft of the screw that attached the exposure counter into the camera is spring loaded. A small spring sits around the screw shaft. But the spring is longer than the shaft, so it is impossible to get any purchase on the threads when I try to screw it into the body. Does anyone have a tip on how to get this reattached?<br>
<br>
Thanks!<br>
<br>
jack fischer<br>
san jose, ca
OP
F
fischer123
San Jose, CA
I didn't see a solution to my problem, but there's a wealth of great info here. Thanks. I did later find my answer at this site:
Argus C3
jack
OLDSKEWL
Oahu, Hawaii
It helps to use a small screwdriver or something to push up on the shaft from underneath and inside the open back just behind the film sprockets while screwing in from the top at the same time.
one90guy
Baytown Texas
Love the Argus C-3's and some of the lens produce really nice images. And in a pinch can be thrown as a weapon.
