school photo's and packages
shanne1020
Biloxi Mississippi
I have been asked by a school to take the pictures the cheerleaders. they are wanting to do it outside. The camera I have is a Nikon 5100. I have the stock lens and I bought the 70-200 auto focus lens. I've played and experimented with this camera and took lots of pictures. I've gotten pretty good with settings..
My first question- will this camera do the job?.. and what about the lens.
2nd question.. how do I go about getting packages printed for each cheerleader?
Any advice will be appreciated
The camera and lens will do the job.
Photographer skill and knowledge is usually what ultimately determines image quality.
You will likely need to use some fill lighting, be it flash or reflected.
A lot of new photographers don't realize that supplemental lighting is usually needed when shooting outside.
Mid-day sunlight can be very harsh and cast deep shadows that make for unflattering lighting for doing high quality photography. When the light is like that, diffusing the harsh sunlight can help a lot. If it is overcast, flash can really add some 'pop' to your subjects, particularly if the flash of light is from off the lens axis (Off Camera Flash, or OCF)
So hopefully you can use the quality and direction of the outside light to your advantage.
Scroll down to see the lighting setup used outside here - Strobist: On Assignment: Kai-Huei Yau's Football Previews
Pretty much all digital images need some amount of post process image editing. One important edit is sharpening the image to correct for the focus softening caused by the anti-aliasing filter in front of the camera's image sensor. Image sharpening is best done as a 3 stage process - capture sharpening, local/artistic sharpening, and output sharpening.
A variety of image factors, like edge frequency and image content, determine how much and what kind of sharpening should be done.
As far as packages, Miller's Professional Imaging has a pic-a-pac service that is hard to beat. Miller's Professional Imaging
Web sites:
http://neilvn.com/tangents/flash-photography-techniques/
Strobist: Lighting 101
Books:
Direction & Quality of Light: Your Key to Better Portrait Photography Anywhere
Off-Camera Flash Techniques for Digital Photographers
Minimalist Lighting: Professional Techniques for Location Photography
As an Amazon Associate we earn from qualifying purchases.
I have been asked by a school to take the pictures the cheerleaders. they are wanting to do it outside. The camera I have is a Nikon 5100. I have the stock lens and I bought the 70-200 auto focus lens. I've played and experimented with this camera and took lots of pictures. I've gotten pretty good with the settings
Oh, well, as long as you've played with it enough, you can do anything! Weddings, inaugurations,etc.
Is this a paid commission, or a 'parent helping out the school' scenario? If it's the latter, then go ahead, do your best, and how it works out is how it works out. If it's the former, well... the tone of your post rather leads me to think you may not be at the level you need to be to properly discharge this.
I took a quick look and most of your subjects are under exposed or have dark eye sockets (raccoon eyes).
The backgrounds are generally under exposed too.
Put another way your subjects don't 'pop' from the backgrounds.
Do you use the portrait framing camera orientation, because on the first page they are all landscape framing ?
Optimizing Exposure
ETTR
Tones & Contrast
Sharpening & Detail
I did use portrait framing on some of the photos I took.. These worked better with the website do I used these.. and I do like to mix it up abit.
I didn't use flash on these and it was late in the afternoon. I was experimenting with iso settings. the ones I used the flash seemed to bright.
I never really got the basics of flash lightening until I bought two flashes and my SU800 controller.
I was originally inspired by this short video, which was really about the SU800 and radio triggers. But it goes through with a basic flash technique and then improves it - albeit on one single model in a studio, versus outside.
PocketWizard® - Using your Nikon SU-800 as a Master Controller
The video isn't much, but it shows the progression of the flash shot. The books and links KmH provide are awesome too.
It is so easy to get overwhelmed with "technology & technique" but that video, for me, simplified it and helped everything make sense. At least at the beginner stage.
Then it made reading the Lighting 101 much easier because I understood the flash and doing Manual 1/128, or 1/32 , the backflash, an umbrella and soft box which were all used in that video.
I'm doing some freebie shots of my soccer teams in action and portraits.
The "package" is the most complex part for me .. but it's just using the Walmart printer machines that they have.
My first attempt at sports I basically have 3 or 4 shots on a 8x10 of someone making a goal. I think it was neat at first, but the composition of the entire page needs work looking back. But you have to start somewhere.
My philosophy when I started my business was I don't do any paid job that i'm not experienced in. At this point in time if you've never done this before you should pass up on the job to risk looking bad, go out, do your research, practice get the experience and then talk to them next year.
thanks KmH.. I will work on that.
Tireiron.. no thoughts really
To elaborate: While I don't mean to seem rude, if you're 'experimenting' with ISO settings, that indicates to me that you're not totally familiar with your camera, equipment, and technique. Fair enough, we all started somewhere, but that also makes me think that taking on a commission such as shooting a cheerleading squad might be a bit beyond your ability right now. Granted, you could do it all against a concrete wall with your pop-up flash, but you're not likely to enhance your reputation by doing that.
You could also do it with one or two off-camera speedlights as astroNikon indicated; the SU-800 allows a LOT of flexibility, but there's a reason why almost every major volume photographer comes in with either a Broncolor, Speedotron, or Dyna-lite set-up; you need reliable light with fast recycle times, and a system that can do that all day long. Speedlights were NOT built to do that. Why not talk to some local pros who may be more skilled in the areas of volume shooting and lighting and working with them on this? It would be a fantastic learning opportunity, and you could still keep your name on the job.
