Seeking Opinions: SB-28
OrionsByte
N. California
Prelude: an acquaintance has a "lightly used" SB-28 from back when his wife did wedding photography, and he has offered to give it to me.
The problem: I'm shooting with a D7000, and all my OCF work to date has used a single SB-600 and Nikon's CLS system using the pop-up flash in commander mode. The research I've done tells me that the SB-28 will only work on the hotshoe of the D7000 if I run in full manual, and I wouldn't be able to use it off-camera unless I picked up an SU-4 or some radio triggers.
So I'm trying to decide whether or not it's even worth accepting the gift. Even if I bought an SU-4 I'd have to run my OCF setup in full manual, but that doesn't really bother me. Pocket Wizards or eBay triggers would probably solve the problem too (and ultimately they're a good investment regardless), but I'd still have to run the SB-28 in manual.
So, opinions: is it worth it? I'm already saving up for an SB-900 (unless I chicken out before then and get a Nissin or something instead) but in your opinion, would the SB-28 have any value to me in my current setup?
I think you mean a SU-800? I would use the SB-28.
The SB-700, SB-800, and SB-600 have a SU-4 mode.
I haven't used a Nikon speedlight or CLS in ages. Radio triggering and manual mode is just so much easier to use.
What are you using them for? I would use them. The sync speed isn't too much but I think they are good to have. Can't beat free.
Mostly portrait work. I'm still pretty much learning to use one flash effectively, but I'd love to have a second one for background lighting, hair or rim lighting, etc. It just feels like in order to be able to use the SB-28 at all I'd have to buy additional equipment (either an SU-4 or some radio poppers), which would set me back in saving up for the speedlights I already know I'd like to have.
It is hard to pass up on $FREE but I also don't want to take the guy's stuff if I can't really use it. Just weighing the pros and cons.
I would. That's just me. I still want a few speed lights but these can still suffice. You will just have to learn how to manually set them. I use two vivitar 285 hv's and a 32 inch reflector.
"Never look a gift flash in the battery compartment!"
