I certainly don't know for sure if the D3200 supports high speed sync. The SB-910 does, I think.
...thanks,pgriz.I guess i'm the kind of guy that has to actually "touch" it to understand it.I understand the HSS concept of multiple flashes.What confuses me,is,for example,if my o/c flash duration is,say,1/2000,and i'm shooting at,say 1/2000 there should be no banding,i'm thinking.With that being said,what purpose is HSS?If I'm not mistaken my D7000 has a s/s of 1/250,but something about 1/320....(that i'll delve into)
The main reason for HSS is to be able to use a wide aperture when using fill flash.
Given that this scenario is always in bright sunlight I think it is much easier (and cheaper) to ditch the flash and use a reflector for fill light. No sync speed issues with a piece of white nylon Lol. HSS/Auto FP is definitely a gimmick in my book.
The main reason for HSS is to be able to use a wide aperture when using fill flash. A wide aperture during daylight means a fast shutter speed. But a fast shutter speed (ie, greater than the sync speed) would mean the banding that I mentioned earlier. So to get around THAT problem, the various manufacturers implemented the multiple rapid flashes, which would together "paint" the sensor with light while the shutter slit traveled across it.
At any speed greater than the max sync speed, the shutter is never fully open. So at 1/2000 sec, the first curtain starts to travel down, exposing the sensor at the very top. After a very short pause, the second curtain starts to follow the first curtain, with the gap between the two being the travelling slit that we mentioned earlier. If the flash fires at the opening of the first curtain, and the flash duration is 1/2000 sec, you still won't get a proper exposure, because the shape of the light pulse is almost triangular, with a very fast initial rise to maximum power, then a rapid fall-off of light that forms the "tail" of the light pulse. The total light pulse may be 1/2000 sec, but maybe 80-90% of the light is in the first 20-30% of the pulse. So your travelling slit will record a good exposure at the top of the sensor, and have almost no light at the bottom.
as for being a gimmick? why is it a gimmick? its just another photography tool.
same as auto exposure modes, rear curtain sync, multiple focus points....
a lot of people called auto-focus a "gimmick" when it was first introduced too.
