stony creek waterfall
squirl033
too close to Seattle
some shots of a small waterfall along a nameless stream that flows into the Foss River in the Washington Cascades east of the town of Skykomish...
#1 and #3 for me. Very , very nice work.....any exposure info for us greenies.......Mike
Were you using any filters. The water looks to hot and not silky smooth.
Very beautiful, maybe its just me but my eyes want to see more. Do you have any shot a little higher, or less crop at the top of the waterfall?
awesome shots. any post processing. BTW can you number your pictures?
#1 - lens at 35mm, 4 sec @ f/14
#2 - 35mm, 2.5 sec, f/13
#3 - 28mm, 6 sec, f/13
#4 - 94mm, 2.5 sec, f/13
all shot manual mode, ISO 100 from a tripod with a remote shutter release and an ND4 filter.
R6 dude, yes, there was some post-processing done... mostly some tweaks to brightness and contrast, color saturation and contrast.
the creek runs under a railroad track about 20 feet upstream from the falls, so i had to crop it a bit tight to keep that out of the photos... ;)
The waterfall is so soft looking, how do you achieve that effect? Gorgeous shots.
use a slow shutter. you can get some of the effect with shutter speeds as fast as 1/2 sec., but for the really soft look, between 1 and 4 seconds works best. in daylight, you will need to stop down the aperture quite a bit, and may need a neutral density filter as well to "slow down" the shutter, though a polarizer will work almost as well.
I like the composition in #3 the most.
When I saw the first one I knew it was shot in WA (then looked at your location for verification).
