- Joined
- Jul 14, 2011
- Messages
- 4,173
- Reaction score
- 2,551
- Can others edit my Photos
- Photos OK to edit
My friend was getting married. I stole away to grab some images of the venue after the rehearsal:
#1
#2
#1
#2
I think that is lens flare
Rotanimod - do you use layer masks to mask things out? Also are you aware in photomatix you can select the areas to remove ghosting? You probably do if not its really cool and also you can select different exposures for different areas.
The reason why I say this is because the water in the second photo I think would benefit from using the ghosting selection mode and select all the water and then choose what exposure you want. You can then later on add in or out in photo shop with some masking.
in regards the the flares , unless you have nano coating or a polarizer on the lens you will sometimes get those flares and even then you still get flares. If its not bad it does not bother me if ifs bad as I have had in my past pictures I then will try to clone and spot heal it out.
As far as these two photos go, I like #2 the first one I just don't like the composition and building from that view.
I reread my post and I don't see how you can take it insulting. I just asked a question and figured you did, BUT if not I offered some friendly advice. If you took it insulting you must have a personal problem your dealing with because I just understand why you would get so defensive on just a question.. You should take a chill pill dude......
I don't know maybe the word "aware" is what pushed your buttons thats the only thing I see after reading the first few sentences over and over.......
I must of not remembered that I asked you before about editing, I have a busy life and post in a few forums and sometimes don't check back in time...
You should not feel that you have to explain yourself so in depth about your knowledge and what programs you are using and how many times you have told people to de-ghost, it was "just" a simple question and a simple answer would have been fine.
The second image looks rather flat to me.
The first one looks better. I think you could correct the distortion though. The bendy flagpole is a little bothersome.
The reason I ask is because this and don't take this personal. After I view many of your images I see blown out areas in lights and water. Many of your images are very soft and flat. So I wondered if you use masking to help bring out the dark tones back in. If thats the way you like your photos and thats your processing style cool no worries we all have different tastes.
You had posted many times about my composition and I heard you, and have really tried to do better, I hope that it is showing and I know that in other forums people have said I have had good comp on recent uploads. The same way you saw in my past photos and kept commenting about it (because you saw no change in my pictures over a period of time,,,,I assume). This is the same way I see many of your photos with the blown out areas and some ghosting....
With that said, dude I apologize if I offended you....
relaxits just Tuesday
I will keep in mind you understand it all and choose to edit your way :thumbup:.
