Terrace Hill
Discussion in 'HDR Discussions' started by 1hdr4u, Jul 11, 2012.
  1. 1hdr4u
    1hdr4u TPF Noob!
    Jul 10, 2012
    56
    4
    Iowa
    This is a HDR photo of Terrace Hill mansion in Des Moines, IA. I used my Canon eos 60d with kit lense, and used Photomatix Pro software to process it. I'm new to HDR so hopefully I'll learn more on how to make my photos look good.
  2. 480sparky
    480sparky Chief Free Electron Relocator Supporting Member
    Mar 8, 2011
    24,675
    8,740
    Iowa
    The top of it looks dark. The process is pushed too far for me..... the blue sky is gray.
  3. vipgraphx
    vipgraphx No longer a newbie, moving up!
    Dec 1, 2011
    2,415
    440
    Some Where In the Desert
    Not bad at all. I like the colors.
    Few things. As mentioned the top of the building is dark. Some your whites are blowing out in the sky and the building (corner edging) There is some CA going on in the trees and the sky does look a bit dirty so clean that up.
    I think for composition its a bit tight and the picture would benefit from either a wider lens or moving back some to get the whole structure in.
    If you wanted to go for a bit more realistic look that I would adjust the saturation a bit..I personally like vibrant rich photos so this does not bother me one bit.
  4. 1hdr4u
    1hdr4u TPF Noob!
    Jul 10, 2012
    56
    4
    Iowa
    Thanks guys for the suggestions. I'm still learning this and hopefully will be getting better images. I will be posting more photos in the future. I also wanted to add that I think HDR is the most exciting form of photography that they've come up with and I enjoy it very much. Hope you do too.
  5. Netskimmer
    Netskimmer No longer a newbie, moving up!
    Jul 23, 2009
    1,392
    229
    North Carolina
    Welcom to the forum. I haven't done HDR so I can't really comment on that but you seem to have some barrell distortion and the top and bottom of the building have been cut off. It's a pretty building, I can see why you wanted to photograph it.
  6. Blairg
    Blairg TPF Noob!
    May 26, 2012
    102
    4
    Nice picture
  7. Bynx
    Bynx No longer a newbie, moving up!
    Feb 8, 2008
    2,804
    366
    Just outside Toronto Canada
    As has been mentioned a different lens is necessary. But as far as the processing there are a few small things wrong with this. There is a lot of Chromatic Aberration going on which should be fixed. The clouds are kind of dirty and there is dirty splotches on the house. The clouds can be fixed by moving the Highlight smoother to the right. Im not sure if it will affect those dirty blotches on the house or not. Also you should correct the lens distortion so the house lines are vertical rather than leaning in. If you used Photomatix you should have used deghosting on the trees. It seems there was some movement among the branches. Colorwise I like this with the exception of the aforementioned dirty blotches.
