Now this is a cool shot...love the contrast BTW that grass and the BG. Very simple composition but a bit heavy with empty space on the left side. I'd crop most of it so you have a square shot. this would balance it better IMO.
Just to be extra picky I'd crop the left side so its equal distance to the wing of the dragonfly as the right side is to the grass. I really like this shot tho!
-Joe
edit: After looking again I think a nice black and white frame to match the wings would make this shot "pop".
hmm, you seem to have added to the left side rather than crop it off. I meant the opposite. The reason I thought it would work was because it would center the picture better, you can see with this edit that it is heavily weighted to the right... I could do a quick edit if you would like.
Wow, thanks, Can you tell me what contrast and darkness you put it at? Now that I get what you mean I will do the same. And the border! How did you put a border?
glad you like it. I didnt pay attention to any of the settings sorry, I just turned the saturation up just enough so it didnt blow the colors out, the contrast was just to pull some more white out of the greys and then i compensated by lowering the brightness till the water wasn't so washed out.
the frame is the easiest thin to do in photoshop. remember to set the size of your picture before you start doing the frame (im assuming you know how to do that because this shot is just the right size) go to image> canvas size... (a window will pop up similar to image size) look right at the bottom of the window and you will see canvas extention color: change that to white to make the inner part of the border. Now look where you edit width and height, change where it says inches to pixels. Now add 4 pixels to the width and the height (you can change this to whatever number you like but for your picture i used 4) click OK and you have the inner part of your frame. mow go back and do the same thing but change the color to black, for the black part i added 40 pixels. Hope that made sense, sorry it was so long.
