Timelapse
jmyoung1
North Carolina
Just got into timelapse photography. Heres a link to my first vid if anyone has any pointers for me it would be greatly appreciated. Also please subscribe to my channel, tons of ideas in the works.
It looks like you have the basics down. Now I would suggest that you find some sort of subject with which to place in your time lapse. Good luck!:thumbup:
Thanks for the advice, heres another one that I just finished.
Would like to try this. Can you give me directions, in newb language? I have Nikon 7000
about what time frames did you use,then how do you get itto play like a movie!?
thanks, Nancy
Hi Nancy,
I have been shooting timelapses for quite some time already, and there are some issues you have to think of:
First, the speed at which you want to accelerate reality. Think of your shots as photograms of a video. A normal frame-rate is 20-30, that means that each second will show 20 pictures. If you take a picture every 5 minutes, each second of your lapse will equal 100 minutes in reality. Depending on what you want to shoot, you will need to use different shooting times and exposure times.
I would highly recommend you to use a tripod, so every picture has been taken with the same framing. If you plan for moving timelapses, then think of each frame before shooting, or maybe buy (or build yourself) a timelapse dolly.
Once you have taken the pictures, you can mount them with a lot of programs: for mac, I would suggest using the "Time Lapse assembler": easy to use and quick. In windows, the movie maker program itself is a good option (you will need to calculate how many seconds each frame will be, that is, if you are planning for 20frames per second, you have to put a duration of 0.05 seconds per frame).
I have a post in my blog that explains those issues (mainly focused on northern lights, but the technique is interchangeable)
Good luck!
Northern light,
Thanks for the tips. I just downloaded time lapse assembler. I had been dumping stills into Premiere and assigning them 1/30th of a second times, but that crap was taking a long time!!!
