Traditional Jewish Wedding
Tight Knot
Boca Raton, FL
Website
www.lensphotoworld.com
Hi All,
Just wondering if any of you have ever shot a Traditional Jewish Wedding?
I will be shooting one in +- 1 month, and wondered if anyone has any lighting ideas for the "Chuppah" (A canopy mounted on 4 poles, that sits above the Bride, Groom, Rabbi, parents and other participants, under which the actual Wedding ceremony is performed). I don't think I can put the lights under the Chuppah itself, and having lighting around the Chuppah means the lighting has to be lower than the canopy, which will be in the way of the crowd, and the crowd will be in the way of the lighting.
So, if anyone has any ideas, I would be most appreciative.
The only thing I can think of, is to use off camera flash mounted on a bracket.
Looking forward to hearing your ideas,
Thanks,
Bruce
tirediron
Watch the Birdy!
Staff member
Supporting Member
Victoria, BC
Website
www.johnsphotography.ca
No, I've never done one, but from what I've seen these 'chuppahs' are pretty much like fancy versions of those little garden tents people have to keep the rain off at parties; could you ball-bungee a couple of speedlights to the legs firing up and into the canopy? That would be subtle enough it shouldn't bother anyone.
OP
Tight Knot
Tight Knot
Boca Raton, FL
Website
Great idea!! I'm going to have to experiment with that before their big day.
tirediron
Watch the Birdy!
Staff member
Supporting Member
Victoria, BC
Website
What I would start with is a couple of speedlights on triggers, one on each "front" leg, facing the couple, and firing into the canopy. If possible, get an idea of the colour and height/size of the canopy as you may need to gel your lights.
OP
Tight Knot
Tight Knot
Boca Raton, FL
Website
If I'm not mistaken, most chuppah's are white, but I'll find out the color just in case I need to gel the lights.
Great suggestions as usual, thanks so much.
Mike_E
This is the ticket (man I hate these things).
If you can manage it you might rig a speedlight to bounce back to a reflector (super clamp on a lightweight rod that's lashed to the inside of the tent with a short extender and an umbrella holder for a speedlight to aim the light into the reflector) gaffer taped to the inside of the tent.
If you're clever you can even put some foam or a wad of newspaper in the middle of the reflector to make it convex and spread the light even further -not too much though.
If you can manage all of this then consider having one in front and another in back for a kicker.
Good luck
you'll need it. ;)
OP
Tight Knot
Tight Knot
Boca Raton, FL
Website
Good luck
you'll need it. ;)
Hi Mike E
Thanks for the reply.
Interesting ideas, I think I'm going to have to see the structure first, so I can see which ideas would work.
Mike_E
To flesh it out a little for you, you can use 2 or 3 foot sections of 1/2 inch pvc and some 90^0 elbows to make a double rail which will make it easier to zip-tie to the inner structure and also to keep it from twisting.
good luck
MarshallG
Canon 7D
I'm not a wedding photographer, but I'm Jewish.
You need to either see or get a description of the chuppa, because they vary dramatically. Do a Google image search and you'll see what I mean -- at my wedding, it was four poles that had to be held by four people, and there's no way you could have put lighting inside of it.
The best thing is if they let you see it a week in advance, so you can experiment with how to light it. I think that one or two slaved strobes with diffusers pointed upwards would produce beautiful lighting, but it will depends on the design.
OP
Tight Knot
Tight Knot
Boca Raton, FL
Website
Hi Marshall,
The last time I really looked at a Chuppah was at my own wedding 20 years ago. So your advice is perfectly sound and greatly appreciated.
I'll let you all know how it goes, or before if anything strange comes up.
ClickASnap
