Alpha
Troll Extraordinaire
- Joined
- Mar 15, 2005
- Messages
- 5,451
- Reaction score
- 41
- Location
- San Francisco
- Can others edit my Photos
- Photos NOT OK to edit
OK now you're just being difficult.
There is no good reason to suggest that the lab cannot develop this in an alternate developer. Indeed, they suggested they were capable of doing so. Further, the comparison to Tech Pan is correct only insofar as both films are slow and require special low contrast developers for ideal results. The similarities end there. Not only is TP not orthochromatic, but it's red sensitivity is greater than most pan films. It is easily possible to get good looking pictorial development out of a film like this using a different developer. Moreover, I would suggest that the only reason Rollei lists only their special developer on the package is because they manufacture it.
And how is your assessment realistic? How many ortho films have you shot?
Just to be clear. you've not shot and/or developed any orthochromatic film. Is that correct?
Oh, yes I have. Sheet continuous- tone (Tri-X) and Kodalith. As I said, it's not the orthochromatic sensitivity that's the issue, not at all. It's the contrast. Ortho has nothing to do with it.
I don't see what TX has to do with this. And Kodalith can be developed for pictorial uses in...wait for it...a dilute non litho developer.
Kodalith was an orthochromatic film. It is you who are confused. Litho has to do with the developer, not the film. Indeed, some films were made to produce certain results with litho developers. But there is nothing litho about the film itself.
The result is not hard to control. You shoot slow and stand develop in a dilute non litho developer. I've done it myself.
The Rollei RHS developer is not specialized! It's just a plain old hydroquinone-based high speed developer!
Have you even looked at the spec sheet for this film? You get normal results using a normal developer. You get high contrast using a high contrast develoer. End of story. No in-between necessary.
