BananaRepublic
- Joined
- Jul 10, 2014
- Messages
- 1,319
- Reaction score
- 161
- Location
- Eire
- Can others edit my Photos
- Photos OK to edit
Hiya
Here are my ideas for you to think about. Not right or wrong just where I would go with your image
1 straighten the horizon
2 lighten the car on the left slightly at the left hand end
3 lighten the front of the combine just a bit
4 rename it combine eats car
But I am known for being out of the box so feel free to disregard all that have said
When I expanded my I pad image it looked like there was a car or pick up on the left facing away from the combine
I was pretty sure it was a combine in a field...I understand your wanting to add some drama by shooting it on the slant, but even lifting the shadows to get a better view of the machine, it not doing anything dramatic falls absolutely flat; it's just a machine sitting in a field.
I understand that. You might want to try another subject to practice with panning.I’ve tried a few times to get the movement but I don’t find it easy to do well
If you could provide your technical details for the photo, that would help, plus tell us what you were trying to achieve. If you were wanting to show us some movement and a feel of power or excitement, with your setup it's not getting you there. It does indeed look as though it is just sitting in the field - the only clue to movement is that there is long grass in front of it, and neatly cut rows behind it. But it's static - your shutter speed was fast enough that you stopped any motion of the blades.
I don't know how fast these things move, or how dangerous it would have been if slowing the shutter speed would have forced the use of a tripod, making it harder to get out of the way.
But that would have perhaps gotten you a better shot - blades whirling, even some hay flying in the air - something to show the purpose of the thing. IF that's what you wanted to capture. You'll have to tell us what you wanted. The angle doesn't bother me, except it can't compensate for lack of motion.
I could go either way on the tilt though personally I prefer a level horizon. On the first shot my personal feeling is you either go all the way on silhouette or you don't. The image is to low of resolution to do much with, but I'd take the field and combine black, then work on bringing up the color and saturation of the sky. I played with it a little, there's a lot of warm orange that can be brought out that will really pop against the black.
Been a number of years since I ran a combine, but the reality is they move at a pretty slow, consistent pace. Shooting from in front of any moving machine might be more of a problem for the landowner then the operator. Modern machines (combines, tractors, sprayers, etc.) don't require a lot of driver input with all the technology onboard, but they do require concentration, so depending on where the driver's focus was, they could lose track of you, especially in failing light.
Ive done some edits, small perhaps, and this time there two alternate routes, kind off. Ive upped that saturation slightly
