what's this little plastic ring (that I just removed) on my Lumix
Discussion in 'Mirrorless Cameras' started by pstock, Dec 13, 2012.
  1. pstock
    pstock TPF Noob!
    Dec 13, 2012
    4
    Pull out my Lumix DMC LX3 this morning and started getting unusual (and new) System Error (Zoom)
    Looking at the lens, I noticed a little loop strip of thin plastic sticking up from between the inner and second lens pieces. (this is new. I'd never noticed this before. and since I take relative good care of the camera I don't know how it arose.)
    After turning the camera on and off several times and it still failed, I just pulled and removed the plastic bit.
    Afterwards the camera seems back to normal, zooming, focusing and shooting fine.
    So, what have I done? What was/is this bit of plastic?
  2. thevideographer
    thevideographer TPF Noob!
    Aug 28, 2011
    36
    6
    Grand Forks, North Dakota
    Is that a twistie tie?
  3. pstock
    pstock TPF Noob!
    Dec 13, 2012
    4
    You would think so but it actually came out from between the inner and next-outer lens ring.
    3/4 of it was snuggly fitted but 1/4 was sticking out this morning when I went to use the camera. And must have been causing the System Error Zoom problem (or at least I assume so because when I yanked it out completely and removed it, the error went away.)
    I am just trying to understand what service it served originally and whether I need to send it in now to have it replaced (I don't expect I will though, until it and unless it malfunctions.)
  4. Village Idiot
    Mar 20, 2008
    7,275
    406
    A seal? Is the camera supposed to be weather resistant?
  5. GrantH
    GrantH TPF Noob!
    Dec 14, 2010
    380
    13
    Hattiesburg, MS
    That....that right there is the battery.
  6. pstock
    pstock TPF Noob!
    Dec 13, 2012
    4
    Definitely not weather resistant.
    Thanks for your help. I'll write panasonic/lumix to get some insight.
  7. KmH
    KmH In memoriam Supporting Member
    Apr 9, 2009
    41,401
    5,696
    Iowa
    It was likely used as a seal. Some amount of weather/dust resistance and light sealing has to be designed into any camera.
  8. pstock
    pstock TPF Noob!
    Dec 13, 2012
    4
    Hmmm, that's a logic assessment.
    I expect that for some reason, when the lens zoomed out recently, something got stuck and pushed that bit of the seal out.
    I'll check around for getting it replaced.
    THanks for your input.
  9. Village Idiot
    Mar 20, 2008
    7,275
    406
    If you don't you may end up with dust in the lens/camera.
